Community Member
MPLS over GRE tunnel on a 6500
Hi.
Can anyone help me understand why this is happening, please?
Got a 6500 running MPLS in the core; one PE router connecting via gigabit ethernet and another PE via GRE tunnel (MPLS is running over the tunnel).
Inbound traffic from the 'tunnel PE' is switched to the 'gig PE' but not vice versa. The config works fine using a router instead of the 6500.
Here are the interface configs. Apart from ip addressing, config is kept basic and is similar on either side.
interface Tunnel2
ip address 10.1.44.5 255.255.255.252
mpls label protocol ldp
mpls ip
tunnel source GigabitEthernet0/1
tunnel destination 10.1.40.1
interface GigabitEthernet0/0
ip address 10.1.32.2 255.255.255.252
mpls ip
Thx
Community Member
Re: MPLS over GRE tunnel on a 6500
This is not supported on the 6500 plattform. I maybe say som in the Future Navigator but I belive you need the OSM module or SIP 600 blade.
Can you try to configure this in the global mode and probably update us back what is the effect for your mpls tunnel.
Router(config)# mls mpls tunnel-recir
Router(config)#
Command Reference:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a00801ea88c.html#wp1836503
HTH-Cheers,
Swaroop
Community Member
Yes, I'm beginning to see that it's not supported. I've got my workarounds & solutions, I just don't understand what I'm fixing.
Can anyone elaborate on what exactly is breaking in the 6500?
In the meantime I'll try the 'recir' cmd.
Many Thx!
664
