MPLS over Serial links with Hardware Compression
We have a core network comprising multiple nodes (2821s) with 256K - 2M Serial links joining them. The network currently support MPLS TE tunnels to provide load balancing across multiple paths within the core network. I am aware that it is not possible to run software compression (STAC) on these links as MPLS requires CEF switching to work and software compression results in process switching. Is it possible to implement hardware compression and CEF switching concurrently and hence MPLS functionality or will packets still be process switched?
1 ACCEPTED SOLUTION
Re: MPLS over Serial links with Hardware Compression
in fact I do not know the answer to your question. But as a workaround you could use MPLS over GRE and compress the GRE packets. This should work in any case.
Hope this helps! Please rate all posts.
Regards, Martin
Regards, Martin
Martin,
thanks for the suggestion. It works correctly but has highlighted what I believe to be an IOS bug. With MPLS packet debugging enabled on an intermediate router it works fine. Without MPLS packet debugging the intermediate router forwards the paket untagged out the wrong interface. Time for a TAC case.
Gary
Hi Gary,
life and IOS is full of surprises ;-)
I am confident, that you will get a shiny new IOS curing all bugs soon ...
Seriously, I have never heard of the symptoms you are describing. Keep us informed about any relevant development allowing us to learn something new.
Regards, Martin
215
