MPLS PE/CE routing protocol decision
I've to build up a new domestic MPLS network and I'd like to find some guide lines for the best PE/CE routing protocol decision (ie pro, cons, max number of prefix supported, max number of protocol instance config on the PE, example of best config, etc).
I'd like to standardize this protocol decision and config (this is done today in different way by any system engineer configuring the CE..)
Does anybody knows where I can find these info ?
Can anybody answer my question?
Is there a white paper for this topic ?
Tks
Ric
Silver
Re: MPLS PE/CE routing protocol decision
www.netcraftsmen.net/welcher/seminars/scalingmpls.pdf
actually from PE-CE, BGP is the best one because it is very scalable solution. If you go for any other protocol which will impose more cpu processing and other overheads on the router.
regards
shivlu
Do you have an idea of how many ospf processes (associated to a VRF) are supported in a Cisco 7206VXR acting as PE ?
Tks
Ric
Unlimited from IOS 12.3(4)T. Depends om memory available.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtospfvf.html
Silver
before 11.0 ios its ws 28 but now a days are unlimited.
regards
shivlu
Tks mates!
And what about BGP, RIPv2 ? ISIS ?
pro ?
cons ?
Tks
ISIS - Not supported as PE-CE routing protocol
RIPv2, BGP and EIGRP runs as address family context and I am not aware of any limitations other than possibly protocol limitations.
Prefer BGP if possible, makes life easier as you not have to redisribute into BGP.
354
