Community Member
MPLS QoS at PE Edge on Subinterface
Hi there,
Currently, Im using below configuration for PE router for hub and spoke:
class-map match-any P1
match ip dscp ef
class-map match-any P3
match ip dscp default
class-map match-any P2
match ip dscp af31
policy-map QoS
class P1
priority percent 35
class P2
bandwidth percent 40
random-detect
class P3
bandwidth percent 25
random-detect
However, for the internet access, I configured PE-Internet into VLAN because of managed internet access plus with managed firewall.
I tried to applied on subinterface but, I got this error msg on my PE-Internet running on c7200 series:
CBWFQ : Not supported on subinterfaces
Any ideas?
Thanks in advanced.
1 ACCEPTED SOLUTION
Re: MPLS QoS at PE Edge on Subinterface
a VLAN subinterface is a software interface and thus has no hardware queue. So CBWFQ is not supported directly. What you can do is to apply a nested policy:
policy-map shapeX
class class-default
shape average X !specify bandwidth
service-policy output MyPolicy
interface FastEthernet0/0.100
encapsulation dot1q 100
ip address ...
service-policy output shapeX
The policy-map MyPolicy would be the one you tried to apply directly.
Hope this helps! please rate all posts.
Regards, Martin
policy-map shapeX
class class-default
ip address ...
Regards, Martin
Community Member
Martin, Thanks!
219
