Silver
MPLS Routing Issue
in the diagram we are getting 12000 routes from the clinet central loaction.now the issue is that these clinets are directly terminating to my PE.In this case how can we use the summarization becasue everytime we have to use the static routing and the number of location thru the country is 4000 and the vrf routers are 12000.
Re: MPLS Routing Issue
Can you pls elaborate your question. Its not very clear. If you are using static routes then how are you then receiving 12k routes form your central CE.
Although you can limit the number of routes per CE at the PE, which would be a part of you SLA with the customer. But again if you are using static at each location then this should be well under your control.
HTH-Cheers,
Swaroop
Silver
rt now we are having connectivity with the clinet central location and we are getting summarized riutes from the clinet central location but now onwards clinet is going to directly coming on our PE in that case we use the static routing and redistribute that static route in the vrf .So we need at least 3 static routes for each location.
So we want some type of summarization at tht end.
shivlu
142
