MPLS TE: Fastreroute issue/question IOS XR
I have MPLS TE tunnels configured to protect long distance links between routers in the core of the network. I have primary tunnel UP and also the backup tunnel UP, the problem is that when I try to see if fastreroute is ready it seems that is not there. I have to mention that I haven't configured the autoroute announce command on the primary tunnel (haven't done the traffic migration yet).
The configuration is the following:
interface tunnel-te1
ipv4 unnumbered Loopback0
signalled-bandwidth 5000000
destination x.x.x.x
fast-reroute
path-option 1 explicit name primary
interface tunnel-te2
backup-bw 4000000
destination x.x.x.x
path-option 1 explicit name backup
mpls traffic-eng
interface TenGigE0/1/0/0
backup-path tunnel-te 2
interface TenGigE0/2/0/0
Every thing else is already configured (rsvp, osfp-mpls-te)
The output of the show commands are:
RP/0/9/CPU0:router#show mpls traffic-eng fast-reroute database summary
Status Count
Active 0
Ready 0
Partial 0
RP/0/9/CPU0:router#show mpls traffic-eng tunnels backup
tunnel-te2
Admin: up, Oper: up
Src: y.y.y.y, Dest: x.x.x.x, Instance: 222
Fast Reroute Backup Provided:
Protected LSPs: 0
Backup BW: any-class; limit: 4000000 kbps, Inuse: 0 kbps
Protected i/fs: TenGigE0/1/0/0
Is there anything I should be worried about? is this a normal behaviour knowing that the autoroute command is not configured yet?
Many thanks for your help.
Re: MPLS TE: Fastreroute issue/question IOS XR
Javier,
Is the primary LSP going through TenGigE0/1/0/0?
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Yes, that is correct.
As you can see in the "show mpls traffic-eng tunnels" output it says that fastreroute is enabled, but I can not see it in the fastreroute database.
RP/0/9/CPU0:P-MTY01#sh mpls traffic-eng tunnels 1
Name: tunnel-te1 Destination: x.x.x.x
Status:
Admin: up Oper: up Path: valid Signalling: connected
path option 1, type explicit primary (Basis for Setup, path weight 10000)
G-PID: 0x0800 (derived from egress interface properties)
Config Parameters:
Bandwidth: 5000000 kbps (CT0) Priority: 7 7 Affinity: 0x0/0xffff
Metric Type: TE (default)
AutoRoute: disabled LockDown: disabled Policy class: not set
Loadshare: 0 equal loadshares
Auto-bw: disabled(0/0) 0 Bandwidth Requested: 5000000
Direction: unidirectional
Endpoint switching capability: unknown, encoding type: unassigned
Transit switching capability: unknown, encoding type: unassigned
Fast Reroute: Enabled, Protection Desired: Any
History:
Tunnel has been up for: 00:49:17
Current LSP:
Uptime: 00:49:17
Prior LSP:
ID: path option 1 [435]
Removal Trigger: path verification failed
Path info (OSPF 1000 area 0):
Hop0: y.y.y.y
Hop1: z.z.z.z
Do you think this is an issue I should be worried about?
Javier,
Can you provide a "show mpls traffic-eng tu xx detail" for both tunnel 1 and 2.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I already found the issue. On the backup tunnel the back-bw value was lower than the signalled-bandwidth in the primary tunnel.
Many thanks.
250
