Community Member
MPLS TE: Fastreroute traffic switching to primary tunnel
I have the following question regarding MPLS-TE fastreroute.
In my scenario I have Fastreroute working perfectly, when the protected link fails traffic gets switched to the backup tunnel and when the link gets up traffic comes back to the primary tunnel. The question is... is it possible to delay the return of traffic to the primary tunnel after the protected link is up again? or even if is it possible to manually switch traffic back to the primary tunnel?
Many thanks for your support.
Community Member
Re: MPLS TE: Fastreroute traffic switching to primary tunnel
There is a command to do this "mpls traffic-eng tunnels reoptimize timers frequency", if you set this timer to 0 it will never reoptimize the Tunnels even after Primary link is up. The default reoptimization timer is 3600 seconds, or one hour.
You can use "mpls traffic-engineering reoptimize" to reoptimize manually. You can either do all at once or select tunnel at a time.
Hope this was your query...
Edit:
You can use "mpls traffic-eng reoptimize" to reoptimize manually. :-)
Cheers
~sultan
Community Member
If that is true, that is precisely what I am looking for.
Many thanks!
Community Member
Hi Javier,
It works for me (7600 platform), so it should for you too !!
Please let us know how it goes...
Cheers
~sultan
Community Member
Sultan,
I tried your solution in my dynamibs simulation scenario before trying it in production network.
At least in the simulation, the routers keep switching traffic back to the primary tunnel after fixing the link failure.
I don't know if reoptimization influences Fastreroute operation, is that what you have tested in your network? or is it only a tunnel reoptimization scenario that you were using?
Community Member
Hi Javier,
As I understood earlier, you wanted to reoptimize the tunnels, and considering that fast reroute happens over tunnels that would do the trick, infact I too do the same... unless I am missing something...
Let me see if I too can check something in my lab related to your query...
Cheers
~sultan
Community Member
Sultan,
It is not a case of sheer reoptimization, eventhough that switching traffic with fastreroute involves that concept. In fact, what i want to do is work with fastreroute in what is called "non-revertive mode", not switching back to the primary tunnel once a failed link have been fixed. I have been looking for that configuration in the CCO but I still can not find it.
Is that what you have been using? (fastreroute or just reoptimization)
Many thanks,
250
