Community Member
MPLS TE - IP Explicit Path
Hi all,
Just wonder what is the best for the next-address, shall we point to next hop router interface ip or the router loopback ip ?
ip explicit-path name path1 enable
next-address 172.18.255.46
next-address 172.18.255.42
next-address 172.18.255.2
next-address 172.18.255.1
1 REPLY
Re: MPLS TE - IP Explicit Path
Both would work. If you have multiple links between 2 routers and want to force the link through a specific link you can probably use the interface ip.
If you want it to be choosen dynamically you can keep specifying the next-hop as the loopbacks of all the directly connected routers in the Tunnel path.
HTH-Cheers,
Swaroop
369
