MPLS TE w. CBTS
mozolik33
Hi All,
I have 2 questions regarding CBTS [MPLS Traffic Engineering (TE)--Class-Based Tunnel Selection]:
- There is a statement in the documentation "The operation of CBTS is not supported with Any Transport over MPLS (AToM), MPLS TE Automesh, or label-controlled (LC) ATM." Does it mean, ATOM (ethernet xconnect) won't be transported between tunnel headend and tunnel tailend PE routers (Inside the tunnels or in global using IGP SPF path)?
- Is CBTS supported in hardware on 7600 boxes running SRB software?
Any comments will be welcomed.
Thank You
JM.,
Harold Ritter
Jozef,
The statement you are referring to only states that CBTS is not supported for AToM. Although it is not officially supported, it does work.
CBTS is indeed supported in HW.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold,
Thank You for Your answer, officially ATOM is not supported by MPLS TE CBTS (this is the statement from TAC).
Anyway, we have done some tests, there were some problems on application level with FTP & NFS.
jm.,
