MPLS-TE
In MPLS-TE to config explicit route on the p2p links, can it be ip unumbered ? pros and cons of making it ip unumbered
1 ACCEPTED SOLUTION
Re: MPLS-TE
Shafik,
As far as I know, this is still work in progress.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: MPLS-TE
Shafik,
MPLS TE does not currently support unnumbered links.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: MPLS-TE
ok, any plans ios will do this ?, junos does :),lastly does MPLS-TE ER require the p2p ip addresses dumped into igp ?
Re: MPLS-TE
I will check what are the plans for the unnumbered support.
Well, the p2p ip address doesn't need to be in the IGP. For instance you could "advertise passive-only" for isis and only propagate the lo0 interface in the IGP and the TE tunnels would still work fine.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: MPLS-TE
Harold,
thanks, yes isis has the right knob, is it going to be available for ospvv2?
Re: MPLS-TE
Shafik,
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
132
