MPLS VPN / BGP Failover Solution
Internet
C21
CER6------------------CER19
PER4---PR2----PR16----PER17
Iam preapring for MPLS exam and i am trying to implement MPLS VPN in the lab environement..
CER6 & CER19 are customer HQ sites has default route to C21 (Ethernet) . all the clients connects to MPSL vpn and follow default route. I am trying to provide redundancy or failover to all the clients so if CER6 goes down CER19 should inject default route in the mpls network.
CER6 connects to PE4 and CER19 connects to PER17
So if link between PE4 to CER6 fails PER17 should advertise default route..but unfortunatly it's not working.. not sure why.. any idea why ? can someone plz advise..i amnot with BGP config and i think it's BGP config issue but not 100% sure about this..
please find atteched configs..
1 ACCEPTED SOLUTION
Re: MPLS VPN / BGP Failover Solution
can you try this configuration:
PER4
router bgp 4701
address-family ipv4 vrf cust-b
redistribute connected
neighbor 10.1.1.2 remote-as 64550
neighbor 10.1.1.2 activate
neighbor 10.1.1.2 as-override
neighbor 10.1.1.2 soft-reconfiguration inbound
no auto-summary
no synchronization
exit-address-family
CER6_Cust_B
router bgp 64550
no synchronization
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.252
redistribute connected route-map no-loopback
neighbor 10.1.1.1 remote-as 4701
neighbor 10.1.1.1 default-originate
neighbor 200.1.1.1 remote-as 64550
neighbor 200.1.1.1 update-source Ethernet1/0
no auto-summary
PER17
router bgp 4701
redistribute static
neighbor 10.1.1.14 remote-as 64550
neighbor 10.1.1.14 activate
neighbor 10.1.1.14 as-override
neighbor 10.1.1.14 soft-reconfiguration inbound
neighbor 10.1.1.14 route-map set_loc_pref in
no auto-summary
no synchronization
exit-address-family
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 0.0.0.0 0.0.0.0
route-map set_loc_pref permit 10
match ip address 1
set local-preference 50
CER19_Cust_B
router bgp 64550
no synchronization
network 10.1.1.12 mask 255.255.255.252
neighbor 10.1.1.13 remote-as 4701
neighbor 10.1.1.13 default-originate
no auto-summary
Hope this helps! Please rate all posts.
Regards, Martin
Purple
There are a couple of issues I see with your config that need to be fixed up
- you should only need the 'neighbor x.x.x.x defualt-originate' command on your CEs. So remove it from your PEs.
- it does not make sense to modify parameters such as weight and local-preference on prefixes sent between your PE and CE so you should remove that too.
List of changes:
- remove ' neighbor 10.1.1.2 default-originate route-map weight' from PER4
- add 'default-information originate' under 'address-family ipv4 vrf cust-b' on PER4
- - remove ' neighbor 10.1.1.14 default-originate route-map weight' from PER17
- add 'default-information originate' under 'address-family ipv4 vrf cust-b' on PER17
- remove ' neighbor 10.1.1.13 route-map loc_pref out' from CER19
Try those out for a start and see how you go.
Paresh
Still no joy..
Once agian i am uploding my updated config. I will appriciate if someone can tell me what am i doing wrong here? and what should i do to resolve this issue ?
Rits
Bronze
i havent read your configs yet mate as i am eating my dinner just now ;-). BUT have you read up on bgp conditional advertisement? i.e. only advertise X if Y no longer exists.
PER4
router bgp 4701
no auto-summary
no synchronization
exit-address-family
CER6_Cust_B
router bgp 64550
no synchronization
no auto-summary
PER17
router bgp 4701
redistribute static
no auto-summary
no synchronization
exit-address-family
match ip address 1
CER19_Cust_B
router bgp 64550
no synchronization
no auto-summary
Regards, Martin
Bronze
hey guys, out of all of these configs there seems to be the static default to null0 missing. Unless i am missing it it really is needed. I see the redistribute static in martins configs but cant see the actual static route. What martin has done in the last post is exactly correct. When doing default-originate it is better to do the null0 static, then redist static then do neighbor x.x.x.x default blah. Rather than the default originiate in global mode.
Hello Rob,
I would think the static default route to Null0 in this case is not advisable, because this would only work on a router with the full Internet table. Both CE routers do not have it, so the static default to Null0 would really be the one used and this would discard all packets towards the internet.
The two options are:
a) static defaults to the internet gateway
b) internet gateway inserting default route into IGP or BGP (of course with proper filters then).
Regards, Martin
Thanks Martin..i guess i was making some silly mistakes here i knew i haev to apply local Pref somewhere but wasn't confident enough. But that's great you have solved my prob..
romccallum - I am not sure wht you want me to do here but the reason why i have redistribute static on PER17 bcz i have got one more site of same customer connected to PER17 and that site is using static route which i am redistributing.
I have one more question on my CE routers CER6_Cust_B & CER19_Cust_B i have static default route pointing it to Ethernet in of Internet router..do i need this route or not ? bcz the moment i remove this route i lose my default route (which is correct.) or should i inject default route on my internet router wht could be most scalable solution in this situation? The reason behind my question is if you notice vrf routing table of cust-b you will see entry for “B 200.1.1.0/24 [20/0] via 10.1.1.2, 00:42:37” and I want to know in case of design issue is this good practice or not?
PER4#sh ip route vrf cust-b
Routing Table: cust-b
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.1.1.2 to network 0.0.0.0
10.0.0.0/30 is subnetted, 4 subnets
B 10.1.1.8 [200/0] via 150.100.0.17, 00:46:22
B 10.1.1.12 [200/0] via 150.100.0.17, 01:18:39
C 10.1.1.0 is directly connected, Serial2/0
B 10.1.1.4 [200/0] via 150.100.0.12, 01:01:21
B 192.168.1.0/24 [20/0] via 10.1.1.2, 00:42:37
B 192.168.2.0/24 [200/0] via 150.100.0.12, 01:01:06
B 192.168.3.0/24 [200/0] via 150.100.0.17, 00:46:01
B* 0.0.0.0/0 [20/0] via 10.1.1.2, 00:42:37
PER4#
Thanks for your help guys I really appreciate and I have learned a lot from cisco forum
M PER4---CER6-----------|
P PER2 | |
L | |-HSRP-|LAN| |----|Internet|
S PR16 | |
PER17---CER19----------|
Also I have noticed when I disconnect or shutdown my Ethernet 1/0 which connects to Internet router I can’t able to reach internet router from other sites as route BGP route “B 200.1.1.0/24 [20/0] via 10.1.1.2, 00:42:37” disappears from the routing table however I can still ping internet router from CER19 but CER19 doesn’t inject this route to MPLS VPN. I don’t think I need HSRP here as I am running BGP … 200.1.1.0/24 is 3rd party route (Internet router received from Internet service provider) and I guess it’s not good solution to inject 3rd party routes in to MPLS VPN? Or should I amend my access list on PER17 and add 200.1.1.0 network in the access list so it will get local preference of 50 so by this way I will have alternate route?
plz answer my questions..as your contribution is great help to me
I would suggest in your environment to inject the default from the internet gateway through an IGP (RIP, OSPF, EIGRP). It could look like this:
InternetGW:
interface Ethernet0
description to CE routers
ip address 10.100.1.1 255.255.255.0
router ospf 10
network 10.100.1.1 0.0.0.0 area 1
default information originate
ip route 0.0.0.0 0.0.0.0 Null0
CER19
interface Ethernet0
description to internetGW
ip address 10.100.1.19 255.255.255.0
router ospf 10
network 10.100.1.19 0.0.0.0 area 1
and the other CER accordingly. The advantage is, that you can detect a problem in the ethernet switch, i.e. connectivity between your CER and InternetGW router.
Then I would modify the CER BGP config like:
router bgp 65000
network 0.0.0.0
no neighbor 10.1.1.1 default-originate
The latter config would only announce a default route through BGP, when a default route (from InetGW) is present in the IP routing table.
Regarding 200.1.1.0/24: I would not do it, because the default should be sufficient to reach this network. General rule: announce it only if you really need it or you own it.
Regards, Martin
424
