Community Member
MPLS VPN management tools
    Hi folks, I'm looking for a tool we can use to hold a database of routing table's vrf and comparison with then during the time.
Thanks in advanced for your recomendations
1 REPLY
Re: MPLS VPN management tools
I have been using (Dorado Software for Network Provisoning and Managment) Redcell in the past. Its very useful and Scalable and would provide the features you are looking for.
check the bellow link:
http://www.doradosoftware.com/solutions/service-provider-mpls-infra-mgmt.html
Mohamed
260
