MPLS Vrf opsf interfaces not working
P/PE router VRF ospf interfaces unable to receive or advertised routing to and from CE router.
Config attahced.
Routes from PE VRF nortel shld be forwarded to CE router
So are routes from CE 50.50.50.0 network
Any ideas?
Re: MPLS Vrf opsf interfaces not working
Looks to me as if you did not start the ospf process in the VRF. So adjust the config according to:
interface Serial2/0
description MPLS VRF 1:1 connection to Cisco 2611 PPP
ip vrf forwarding nortel
ip address 200.0.30.1 255.255.255.0
encapsulation ppp
clock rate 128000
interface FastEthernet4/0
description MPLS connection for vrf Nortel 1:1
ip address 70.70.70.1 255.255.255.0
duplex auto
speed auto
no router ospf 1
router ospf 1 vrf nortel
network 200.0.30.0 0.0.0.255 area 0
network 70.70.70.1 0.0.0.0 area 0 !In case you want OSPF over this interface as well
With the current config I would assume that you do not see an OSPF adjacency on the CE.
Hope this helps! Please rate all posts.
Regards, Martin
Hi Martin,
using OSPF VRF process has resolved the problem of loosing ospf adjacency, once applied "ip vrf forwarding".
Now, I am getting new problem, Lo0 of the PEs are no longer reachable, regradless the fact OSPF ajacency is established between the P-router to PE-routers and Lo0s are advertised by OSPF VRF process.
Please advise.
The PEs loopback interface should not belong to any particular VRF but to the global routing table. Can you please post your updated configurations.
Cheers,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
200
