Community Member
Multi-VRF CE: Number of VRF's
Are there hard and fast limitations to the number of VRF's you can configure on a given router platform using Multi-VRF CE functionality? Or, are the only limitations those imposed by the available memory, CPU, and available routing processes on a given router.
Re: Multi-VRF CE: Number of VRF's
There is no hard limit that I know of. As you stated the limitation is rather to resources available on the node itself.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Community Member
The number of VRFs supported seem to be platform specific - a 3550 switch will only support 7 VRFs..
Best regards,
David
198
