Multicast, MPLS, and iBGP peering
I had a multi-VRF Multicast configuration going using the following document for configuration:
http://www.cisco.com/en/US/technologies/tk648/tk828/tk363/technologies_white_paper0900aecd8012033f.html
I rebooted both routers that peered via iBGP after an IOS upgrade. The BGP peer would come up, LDP neighbor relationship would come up. As soon as that tunnel would come back up, all traffic would stop and the peer would disassociate. No traffic whatsoever would pass. Any recommendations?
Silver
Silver
Re: Multicast, MPLS, and iBGP peering
are u using the single bgp loopback for the updates for more than one. please paste the configuration
regards
shivlu
Im working on a viewable version of the config. It's really huge. Im using multiple loopbacks for bgp peering on the vrf's, but using loop0 for the main bgp peer. Working on the config.
Here is a brief version of the relevant info on one of the routers- they are both set up the same way:
version 12.4
ip vrf CustomerA
rd XXXXX:1
route-target export XXXXX:1001
route-target import XXXXX:1001
mdt default 239.255.255.1
ip vrf CustomerB
description VRF for CustomerB Pools
rd XXXXX:4
route-target export XXXXX:1004
route-target import XXXXX:1004
mdt default 239.255.255.2
ip multicast-routing distributed
ip multicast-routing vrf CustomerA distributed
ip multicast-routing vrf CustomerB distributed
ip multicast route-limit 200000 20000
ip multicast vrf CustomerA cache-headers
ip multicast vrf CustomerA route-limit 200000 20000
ip multicast vrf CustomerB cache-headers
ip multicast vrf CustomerB route-limit 200000 20000
interface Loopback0
ip address 10.255.0.8 255.255.255.255
ip pim sparse-dense-mode
interface Loopback1
ip vrf forwarding CustomerB
ip address 10.254.0.2 255.255.255.255
interface Loopback2
ip vrf forwarding CustomerA
ip address 10.253.0.1 255.255.255.255
interface Serial0/1/0/3:0
bandwidth 1536
ip address 10.105.255.105 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip igmp static-group 239.194.0.0
load-interval 30
service-policy output cbwfq-voice20per
interface Serial5/0/0:2
bandwidth 1536
ip address 192.168.251.5 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip igmp static-group 239.195.0.0
ip igmp static-group 239.195.1.0
load-interval 30
router bgp XXXXX
bgp log-neighbor-changes
neighbor 10.255.0.0 remote-as XXXXX
neighbor 10.255.0.0 update-source Loopback0
neighbor 10.255.0.7 remote-as XXXXX
neighbor 10.255.0.7 update-source Loopback0
neighbor 10.255.2.0 remote-as XXXXX
neighbor 10.255.2.0 update-source Loopback0
address-family ipv4
redistribute connected
redistribute static
redistribute ospf XXXXX match internal external 1 external 2
neighbor 10.255.0.0 activate
neighbor 10.255.0.0 soft-reconfiguration inbound
neighbor 10.255.0.7 activate
neighbor 10.255.0.7 soft-reconfiguration inbound
neighbor 10.255.2.0 activate
neighbor 10.255.2.0 soft-reconfiguration inbound
no auto-summary
no synchronization
network 10.255.0.8 mask 255.255.255.255
exit-address-family
address-family vpnv4
neighbor 10.255.0.0 send-community both
neighbor 10.255.0.0 next-hop-self
neighbor 10.255.0.7 send-community both
neighbor 10.255.0.7 next-hop-self
neighbor 10.255.2.0 send-community both
neighbor 10.255.2.0 next-hop-self
exit-address-family
address-family ipv4 vrf CustomerB
redistribute static
neighbor 10.250.0.115 remote-as 65502
neighbor 10.250.0.115 disable-connected-check
neighbor 10.250.0.115 update-source Loopback1
neighbor 10.250.0.115 activate
neighbor 10.250.0.115 as-override
neighbor 10.250.0.115 soft-reconfiguration inbound
default-information originate
no synchronization
exit-address-family
address-family ipv4 vrf CustomerA
redistribute static
neighbor 10.253.0.4 remote-as 65512
neighbor 10.253.0.4 disable-connected-check
neighbor 10.253.0.4 update-source Loopback2
neighbor 10.253.0.4 activate
neighbor 10.253.0.4 as-override
neighbor 10.253.0.4 soft-reconfiguration inbound
no synchronization
exit-address-family
ip pim bidir-enable
ip pim send-rp-announce Loopback0 scope 100
ip pim send-rp-discovery Loopback0 scope 100
ip pim ssm default
ip pim vrf CustomerA send-rp-announce Loopback2 scope 16
ip pim vrf CustomerA send-rp-discovery Loopback2 scope 16
ip pim vrf CustomerB send-rp-announce Loopback1 scope 16
ip pim vrf CustomerB send-rp-discovery Loopback1 scope 16
Silver
i am not getting any improper configuration from your post. What i am thinking off that the problem with the RPF only. Please check the RPF is it succeeded or not.
Becaseu you r having one MP-BGP peering ; if u have more than one BGP peering in your cloud then the problem comes.
regards
shivlu
307
