Nexus 7009 EoMPLS L2VPN for VLAN Trunk
Problem: Howto configure EoMPLS L2VPNs on Nexus7000 for Layer2 VLAN
Trunking ?
   I have TWO HW and SW identical Nexus 7009 with Sup2E running under
NX-OS 6.2(2a) with HW Modules:
Mod  Ports  Module-Type                         Model              Status
1    0      Supervisor Module-2                 N7K-SUP2E     active *
2    0      Supervisor Module-2                 N7K-SUP2E     ha-standby
3    24     10 Gbps Ethernet Module             N7K-M224XP-23L     ok
4    24     10 Gbps Ethernet Module             N7K-M224XP-23L     ok
5    48     1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L     ok
Both Nexus7009 are running in an MPLS Backbone using L3VPNs for
different customergroups.
The hostname and Loopback Adresses of the two Nexus 7009 are listed below:
1.st Router
hostname: N7K-R1-gw
Loopback0 Address: 172.17.127.110
Interface: Ethernet 3/24
2.nd Router
hostname: N7K-R2-gw
Loopback0 Address: 172.17.127.5
Both Nexus7009 are connected via Ethernet Interfaces Eth3/24
to our MPLS Backbone; Interfaces are configured with:
mpls ip
mtu 9216
I need to configure a Point-to-Point L2VPN (Ethernet over MPLS) between
the two Nexus 7009 in oder to trunk several VLans over this L2VPN. I
tried the following Configuration:
Configuration on Host: N7k-R1-gw:
feature-set mpls
feature mpls l2vpn
l2vpn
feature evc
l2vpn xconnect context to_N7K-R2-gw
  member Ethernet5/25
  member pseudowire10
interface pseudowire10
  neighbor 172.17.127.5 10
  encapsulation mpls
  mtu 9216
interface Ethernet5/25
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 410,414
  mtu 9216
  no shutdown
Configuration on Host: N7K-R2-gw:
feature-set mpls
feature mpls l2vpn
l2vpn
feature evc
l2vpn xconnect context to_N7k-R1-gw
  member Ethernet5/1
  member pseudowire10
  neighbor 172.17.127.110 10
  encapsulation mpls
  mtu 9216
interface Ethernet5/1
  description --FREI--
  switchport
  mtu 9216
  no shutdown
N7k-R2-gw# sh mpls l2 vc
Local intf     Local circuit              Dest address    VC ID      Status
Eth5/1         Ethernet                   172.17.127.110  10  DOWN
N7k-R1-gw# sh mpls l2 vc
Eth5/25        Ethernet                   172.17.127.5    10  DOWN
N7k-R2-gw# sh int pseudowire10
pseudowire10 is down (other)
  Hardware: Pseudowire
  MTU 9216 bytes
  Encapsulation mpls
  Auto-mdix is turned off
  Peer IP 172.17.127.110, VC ID 10
  RX
    Total: 0 pkts, 0 bytes
  TX
N7K-R1-gw# sh int pseudowire10
  MTU 9216 bytes
  Encapsulation mpls
  Peer IP 172.17.127.5, VC ID 10
  RX
  TX
N7k-R2-gw# sh int eth5/1
Ethernet5/1 is down (Remote port is down in L2VPN service)
N7k-R1-gw# sh int eth5/1
Ethernet5/25 is down (SFP not inserted)
admin state is up, Dedicated Interface
Any ideas whats going wrong ? Maybe I do not understand how it
works.
Thanks in advance Manfred
1 REPLY
HI Manfred, Can you configure
HI Manfred,
Can you configure the attachment circuits(e5/1 and e5/25) in either vlan or port mode?
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/mpls/configuration/guide/mpls_cg/mp_l2vpn_atom.html#pgfId-1065574
Best Regards,
Bheem
572
