Not able to reach to Router
In my network I can see ip route to particular destination but not able to ping
Pl. guide
Router#sh ip route vrf ABCD x.x.x.x
outing entry for x.x.x.0/24
Known via "bgp 9730", distance 200, metric 0, type internal
Last update from y.y.y.y 1w2d ago
Routing Descriptor Blocks:
* y.y.y.y (Default-IP-Routing-Table), from y.y.y.194, 1w2d ago
Route metric is 0, traffic share count is 1
AS Hops 0
Router#ping vrf ABCD ip x.x.x.x
Sending 5, 100-byte ICMP Echos to x.x.x.x, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Mahesh
Re: Not able to reach to Router
Pls check two things
1.In the remote PE , see wheter you are able to learn the route of the VRF ABCD connected interface of the router from where you ping . ( Check under your address family ipv4 vrf ABCD , wheter redistribute connected given )
2.If the destination is customer end , check wheter you are learning the route of the connected interface .
If both are fine , check wheter labels are exchanged properly at both sides
Hope this helps
regards
vanesh k
See
the router from which I ping is not directly connected with the device I ping..
My Router--ds3 link---->another router---E1 link (172.30.101.58/30)--> router I ping (It is Customer end)
And from My router I am doing ping to 172.30.101.58.
this is the scenario
if need more information kindly tell me
Kindly guide
Mahesh
To make it clear ,
In " my router " , you will have a vrf ABCD enabled interface right , Pls check wheter that connected interface route is learned in "another router " , bcause a vrf ping would take , the connected ip of "my router " as source . Similary check for the routing in the CE also for the connected interface ip of " my router "
Hope this helps
regards
vanesh k
see,
from my router i can telnet to another router and from that router i am able to telnet to CE .. But from my router i am not able to reach to CE.
My router Config:
ip vrf ABCD
rd 9730:85
route-target export 9730:51
route-target export 9730:92
route-target import 9730:52
route-target import 9730:53
route-target import 9730:92
address-family ipv4 vrf ABCD
redistribute static
no auto-summary
no synchronization
exit-address-family
Another router config:
ip vrf ABCD
rd 9730:85
redistribute static
no auto-summary
no synchronization
exit-address-family
and there is no any static route defined in any of two router.
Pl. guide
Mahesh
Dear Vanesh,
TEll me one thing if a vrf is configure in two router ..and both have identical configuration regarding to that VRF. what else is needed to reach to CE (which is connected to another router) from my router
I think i am missing something in config that's why not able to locate the problem
Hope this will useful to u to solve my problem
Mahesh
Mahesh,
are you sure you don't need:
ping vrf ABCD 'CE' source 'one of your ABCD i/f'
it should work if you specify source since this is vrf-specific ping.
Hi Mahesh,
Can you confirm that in ur core mpls ip propagate-ttl is configured or not
Cheers 1
It is by default enabled and it is in our compan's policy to keep it as default
regards
Mahesh
Pls check
1.Whether from "another router " you are able to ping the ip
2.If you are able to ping , check wheter the customer is having default route or some specific routes
3.If default route , then need to check in terms of labels , if static route then check wheter the connected route of "my router " is added at cpe end .
regards
vanesh k
--Ya from another router i am able to ping
-- customer is able to learn route to another router via OSPF
CE: Routing entry for 172.30.6.0/24
Known via "ospf 100", distance 110, metric 20, type extern 2, forward metric 150
Regards!!
Hi ,
What abt the route for /30 connected ip of "my router " vrf ABCD interface
regards
vanesh k
Dear vanesh,
Now it is clear I am attaching one file for diagram.
Look at that and problem is there
Pl. suggest me necessary config
Regards!!
Its simple , I think you are running OSPF between your PE and CE . Do a redistribution of the BGP routes in the ABCD VRF into OSPF
configured for the customer .
It would make the customer routers to learn the routes
Router1(config)# router ospf 2 vrf v1
Router1(config-if)# log-adjacency-changes
Router1(config-if)# redistribute bgp 1 subnets
Hope this helps
regards
vanesh k
isn't there any other way instead of configuring sham links?
where should i configure on CE or PE..B'se on PE I have no config related to OSPF.
Regards!!
Hi mahesh,
Pls donot get confused with sham link , I thouhgt that Router B and CE1 are running OSPF , so I said to redistribute the connected route learned from A via BGP into OSPF .
Pls let me know how B and CE1 route exchange happens. ( Static or any routing protocol )
regards
vanesh k
Dear,
CE2# sh ip route 172.30.6.1
Last update from 172.30.103.2 on Serial0/2:0, 00:56:38 ago
* 172.30.103.2, from 172.30.170.73, 00:56:38 ago, via Serial0/2:0
Route metric is 20, traffic share count is 1
But why no OSPF configured in any of PE's.
Regards!!
From the routing info , the CE1 and CE2 are ruuning OSPF and since 172,30,6.0/24 is a connected interface in CE1 , so its getting redistributed to CE2 as E2 route .
Either CE1 should have a default route pointing to your PE router or a static route for "My router " subnet to the PE router or should run a routing protocol to work.
Pls check and do as per the requirement.
Hope this helps
regards
vanesh k
Hi Mahesh,
can you do the VRF trace and check if stucks somewhere ?
Cheers.
Mahesh
Just as Vanesh has mentioned the reverse route to the ping source (172.30.3.1/30 router A vrf ABCD interface ) is missing in the CE2. Please put a trace to ip 172.30.3.1/30 from the CE2, to find out where the route is specifically needed.
Dear all,
thanks for your valuable input..
Now i can't test any more commands on CE Router ..B'se customer is getting the routes they needed ..But I am not getting b'se it is not in customer's interests.
anyway really very thanks for your support.
I hope in future also i will be given good support to solve problems
Mahesh
220
