03-11-2008 12:24 AM
Layer 2 VPN is provided to one of my client who has Serial interface on one end and Ethernet on the other side.
Using IP Interworking L2 circuit is provided.
Unicast ping is working fine but unable to bring OSPF across this L2 circuit.
OSPF remains in INIT state only.
Tried âip ospf network point-to-pointâ on Ethernet interface still no luck..
Any clue whether multicast is supported across IP Interworking kind of circuits ?
03-11-2008 05:02 AM
Are you seeing hellos across the link (debug ip ospf hello)? If so, please check the MTU settings on both interfaces and set the OSPF link type (point-to-point).
If there are no OSPF hellos received you have to ask your provider to troubleshoot the problem with you. In principle it should work.
Hope this helps!
Regards, Martin
03-11-2008 11:15 PM
Thanx for responding..
after issuing debug ip ospf hello i observed that site A is receiving hellos sent by site B but Site B is not receiving hellos sent by site A.
MTU used for establishing Pseudo-wire is 4474 and that of ospf interfaces (i.e. CPE interfaces) is set to 1500.
03-12-2008 05:28 AM
The MTU is compared in database description packets an they will come at a later stage. You can confirm, that A is sending hellos? Then you need to contact the provider to troubleshoot inside the MPLS cloud, namely why the VC does not forward the hellos.
Regards, Martin
03-13-2008 12:17 AM
Thanx Martin
Got the same setup tested in lab and found to be working.
