Packet drop?
I have a problem. Should unlabelled traffic get dropped by a router where MPLS is active on all interfaces ?
Hall of Fame Super Silver
Re: Packet drop?
No,
unlabeled IP packets can be routed if there is a routing entry for them (or a default route).
Actually, in service provider networks to save labels (because the label space in a node is limited) the routers are configured with ACL that define for what IP prefixes labels have to be assigned.
In a service provider scenario using iBGP it is enough to have labels assigned for the loopback interfaces used as endpoints in iBGP sessions.
An example in old syntax is:
access-list 20 permit 10.240.0.0 0.0.3.255
no tag-switching advertise-tags
tag-switching advertise-tags for 20
this works if all loopbacks are in the allowed IP prefix
hope to help
giuslar
Re: Packet drop?
Interesting. Thanks!
But if the interface they are coming at is in a vrf and there is no route to destination in this vrf, shouldn't the router look in the global routing table by default ?
Re: Packet drop?
No by default it will do not look up in global routing table..This is how access to and from sites in a vpn are limited to only that VPN. There is way you can do this..by leaking the routes.
301
