Bronze
PE-CE EIGRP redistrbution to M-BGP Problem
I'm using EIGRP as PE-CE routing protocol . Our customers are DSL's which are connecting on PE router as virtual interface .
The following is my PE config.
router eigrp 1
no auto-summary
address-family ipv4 vrf mpls-test
redistribute bgp 65000 metric 1000 100 255 1 1500
no auto-summary
autonomous-system 1
exit-address-family
router bgp 65000
redistribute eigrp 1
no auto-summary
no synchronization
exit-address-family
DSL_Router1#sh ip vrf mpls-test
Name Default RD Interfaces
mpls-test 1:101 Lo3
Vi4551
On CE Router I did the basic EIGRP config , without neighbor statement as I can't do the neighbor with PPPoE Dialer interface . Is there is anyway in my case
Haris
1 REPLY
Hall of Fame Super Silver
Re: PE-CE EIGRP redistrbution to M-BGP Problem
Hello Haris,
in the EIGRP command reference I've found this suggestion:
VMI Interface Aggregation Point
see
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_eig1.html#wp1012421
The VMI interface acts as an aggregation point for multiple PPPoE connections from one or more radios over one or more physical interfaces.
and also:
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_cfg_eigrp_ps6922_TSD_Products_Configuration_Guide_Chapter.html#wp1054195
Hope to help
Giuseppe
307
