Point-to-point MPLS
Hello everyone,
I would like to configure two routers back to back MPLS. Each router has 2 interfaces. One to face the "cloud" and one to face the customer. The cloud is nothing more than a VLAN in which there are no other routers. The 2 MPLS end points are one the same IP segment and actually CDP see each other. I would like to take everything from the customer facing interface, encapsulate it, send it to the neighbor router and strip the MPLS tag and push it out the other non-cloud interface.
Thoughts?
Any help would be appriciated.
Thank you,
Steve
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Point-to-point MPLS
Hello Steve,
it is really possible to do what you want.
First on the two routers you enable mpls
conf t
int loop1
desc MPLS router-id
ip address 1.1.1.1 255.255.255.255
mpls ip
mpls label protocol ldp
on common segment
int gi0/0
desc mpls backbone link to other PE
mpls ip
this provides the MPLS infrastructure.
Now to send traffic between the two customer sites the best is to use an MPLS VPN made of two VRF sites
ip vrf Customer1
rd 1:1
route-target both 1:1
int f0/1
desc VRF access link facing customer
ip vrf forwarding Customer1
router bgp 1
no bgp default ipv4-unicast
neighbor 1.1.1.2 remote-as 1
neighbor 1.1.1.2 update-source loop1
address-family vpnv4
neighbor 1.1.1.2 activate
neighbor 1.1.1.2 send-community both
address-family ipv4 vrf Customer1
no sync
no auto-summary
redistribute connected
Do the same on the second router that will use a different IP address for the loopback
There is no need for a P router between the two PE routers.
For penultimate hop popping MPLS VPN packets will be sent out with a single label the VPN label advertised by BGP multiprotocol in address-family vpnv4.
May be your question was only about the possibility to use MPLS VPN with two back to back PE the answer is yes.
Hope to help
Giuseppe
Hello Steve,
conf t
int loop1
desc MPLS router-id
mpls ip
on common segment
int gi0/0
mpls ip
ip vrf Customer1
rd 1:1
int f0/1
router bgp 1
no sync
no auto-summary
Hope to help
Giuseppe
Giuseppe,
Great response. Thank you. The only other line I added was ebgp-multihop. Maybe I don't need it. I will try it both ways. Either way, thank you.
Steve
163
