Community Member
Problems with Converge Times between BGP and IS-IS
Hello together,
in our MPLS Core we use IS-IS as Routing Protocol between P- and PE- Router. And we use mBGP for VPN based Routing (vrf) between the PE Routers.
At the begining everything works fine. But now it seems that the convergence times between IS-IS and BGP has increased.
e.g. when a link in the core fails than it took more then 5 minutes till the BGP Neighbours are reestablished again. Within the 5 minutes the ip connectivity is there but is not proper propagated withinh IS-IS.
Are the there any configurations issues (e.g. timers)to optimize the behavior between IS-IS and BGP ?
Thanks in advance for an response.
1 REPLY
Community Member
Re: Problems with Converge Times between BGP and IS-IS
On he BGP side you can reduce the keepalive from the default of 60 seconds to for example 15 seconds. I would keep the holdtime at 3x this. This will save you about one minute.
e.g.
router bgp 1
timers bgp 15 45
You can gain another minute by reducing the BGP scan time with,
router bgp 1
bgp scan-time 10
Ian
208
