Pseudowire MPLS
I need one cisco router which can support the more than 20 T1 from customers and support the Pseudowire Technology... between two main router and then again more than 20 T1 output...
topology like...
---20T1--CiscoRouter---Pseudowire---CiscoRouter---20T1---
So its something looks like the multiplex and then run IP network and then demultiplex...
regards
Devang
  • MPLS
Re: Pseudowire MPLS
Dear Devang,
Cisco 7206 with PA-MC-8T1 Port adaptor can take 48 T1.
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_module_installation_guide_chapter09186a008007cfab.html
Best Regards,
Mounir Mohamed
Re: Pseudowire MPLS
The 7206 is a fine box, but since it's a software based platform, you should verify that it meets your performance needs. Performance on the 7200 will vary on based on processor (NPE), port adapter, IOS features. Another option is the 7600. Since switching is done by hardware asics on the 7600, performance will be fairly constant on the 7600 (so long as all the features you're doing are supported by the asics).
154
