QoS Setup issue
When setting up QoS on a 2801, I get the following error when trying to apply the service-policy to the interface.
I/f Serial0/1/0:0 class CRITICAL requested bandwidth 49%, available only 25%
The service provider only provides me with a 50%/49% QoS policy to work with. Attached is the QoS config I'm trying to use. Every time I try to run the last step, I get the same error.
1 ACCEPTED SOLUTION
Re: QoS Setup issue
by default it is possible to reserve 75%, with 25% avaliable for default class.
command max-reserved-bandwidth changes default
Try
int ser 0/1/0:0
max-reserved-bandwidth 99
Service-policy out xxx
Jon
1 REPLY
Re: QoS Setup issue
Try
int ser 0/1/0:0
Jon
108
