Question on MP-BGP Session
Hi Sir,
I have the following BGP configuration of an RR and a PE in an MPLS VPN environment:
RR
router bgp 65000
neighbor 2.2.2.2 remote-as 65000
neighbor 2.2.2.2 update-source Loopback0
neighbor 2.2.2.2 route-reflector-client
address-family vpnv4
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 send-community extended
exit-address-family
PE1
router bgp 65000
no bgp default ipv4-unicast
neighbor 1.1.1.1 remote-as 65000
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-comunity both
neighbor 1.1.1.1 next-hop-self
exit-address-family
Theorectically, given the above config, can the two routers successfully peered?
(1) The RR is configured to exchange IPv4 and VPNv4 routes and exchanges only extended BGP communities.
(2) The PE router is configured to exchange only VPNv4 routes and exchanges both standard and extended BGP communities.
Please advise.
Thank you.
B.Rgds,
Lim TS
1 ACCEPTED SOLUTION
Re: Question on MP-BGP Session
IF you have anymore queuries regaridng the same, pls respond.
Or we can close the thread, if have answered your query.
HTH-Cheers,
Swaroop
In the above scenario what will happen is,
1) The RR will show a NoNeg state for normal IPV4 session. Assuming you have not activated the IPV4 address-family for the RR on PE1.
2) On PE1 side you will not see any neighbor when you want to see IPV4 neighbors.
3) For VPNV4 both sides agree upon and the peering happens, and they exchange VPNV4 updates.
Now, generally in a MPLS scenario, to avoid IPV4 peering, the default behaviour of BGP to form IPV4 peering is turned off on RR, and not on PE. So when ever a PE tries to peer on both IPV4 and VPNV4, all the PE's would see NoNeg state for IPV4 with the RR and VPNV4 will work as usual, and all the VPNS would be able to exchnage routes and other updates.
If you want to have IPV4 peering also, on a per neighbor basis, what you can do is where you have turned off default IPV4 peering, in that address-family you will have to specifically activate the neighbor for IPV4 as well. For Example: you have turned off IPV4 peering on PE1, so you will have to enter IPV4 address-family on PE1 and activate the RR neighbor IP. so they exahnge IPV4 and VPNV4.
HTH-Cheers,
Swaroop
HTH-Cheers,
Swaroop
395
