Redistribute MPLS/eBGP to EIGRP- Two companies Migration
I have a question about two companies migration Iusse, Attached scenario should give most of the information.
Company A got two router R1 and R2 running EIGRP100 with the service providers 1
Company B got R3 Running MPLS BGP with same service provider 1
Company A is migrating with Company B
After migration Company A and B should be takling internally
With the Below Configuration, I can reach from company A to B, but Not from Company B router to Company A Not sure what I am missing in my configs  Or is there a better way to migrate two copmanies with out creating new EIGRP AS?
Company A Router 1
router eigrp 100 <----To ISP 1
redistribute connected
no auto-summary
eigrp router-id 10.10.10.1
network 10.0.0.0
network 172.17.10.0 0.0.0.3
router eigrp 200          <---- to Company B
no auto-summary
eigrp router-id 192.168.200.5
network 172.16.10.0 0.0.0.3
Company A-R1#ping 192.168.200.1- This is in VRF on Router CompanyB
Sending 5, 100-byte ICMP Echos to 192.168.200.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Company B Router configuration
How can I redistribute the routes learned [through redistribute connected/static] into EIGRP 200
router eigrp 200( built new EIGRP 200 to get routes from Company A and keep them seperate)
redistribute bgp 200 metric 10000 2000 255 1 1500
no auto-summary
eigrp router-id 192.168.200.1
router bgp 200          <-----eBGP to ISP 1
bgp router-id 172.15.10.1
bgp log-neighbor-changes
address-family ipv4
  no auto-summary
  no synchronization
exit-address-family
address-family ipv4 vrf test1
  redistribute eigrp 200
  neighbor 172.15.10.2 remote-as 54321
  neighbor 172.15.10.2 update-source Vlan555
  neighbor 172.15.10.2 activate
  neighbor 172.15.10.2 soft-reconfiguration inbound
  no synchronization
  network 10.50.60.0 mask 255.255.255.192
  network 172.15.10.0 mask 255.255.255.252
  network 192.168.200.0 mask 255.255.255.252
exit-address-family
company B#ping 192.168.200.5
Sending 5, 100-byte ICMP Echos to 192.168.200.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
R4#ping 192.168.200.1
Can someone guide me what I am doing wrong?
  • MPLS
2 ACCEPTED SOLUTIONS
Hi Blach
If I understand your requirement correctly you want to advertise the VRF-Specific Subnet 192.168.200.0/32 which is present in a VRF on Company B to be available to both the eBGP peering to ISP-1 and to the Company-A-R1. If I understand it correctly then we can make the peering to Company-A-R1 on Compnay B also VRF Specific and create VRF Specific EIGRP Process on Company B Router
Something like this below on Company B router
router eigrp 200
no auto-summary
address-family ipv4 vrf "VRF_Name"
no auto-summary
exit-address-family
Varma
Re: Redistribute MPLS/eBGP to EIGRP- Two companies Migration
Hi Blach
If we configure the L3-Link on Company B facing Company-A-R1 into VRF and also accordingly add the EIGRP 200 into VRF on Company B, on the Company-A-R1 we need not do any VRF specific configuration and everything can remain in global routing table. Not sure if there are some security policies which makes it mandatory to do same VRF specific config at Company-A-R1 also. But feasibility wise only doing configuration on Comapny B  will be fine.
Taking the scenario into consideration where we have to send the VRF specific routes of Company B into the Global ROuting Table peering with Company A-R1, the only complex option would be use the route-leaking concept of Internet Access in a VRF using Global Route-Leaking which relies on applying a Static Deafult VRF route under the VRF context point to a Global IP Next-Hop with keyword global and also to create Global Routing Table Specific reverse static routes for the VRF Subnets pointing to the VRF Interface.This concept will not work for leaking directly connected VRF routes into Global Routing Table. So all in all it would be something like as below:
E.G)
On Company B
ip route vrf test1 0.0.0.0 0.0.0.0 172.16.10.1 global
ip route x.x.x.x y.y.y.y "Interface"
router eigrp 200
redistribute static
I would personally suggest to you option 1 of creating VRF specific EIGRP config.
Varma
VIP Super Bronze
On router-B, is 192.168.200.1 in a vrf? What happens if you take the interface out of the vrf? can you ping it than?
On router-B is the interface that connects to router-A also in the same vrf?
can you post full config from both routers?
Hi Blach
As Reza has asked above for clarification regarding VRFs and from your comments above it seems you have Global Peering between Comapny B and Company-A-R1 but we are trying to ping VRF routes of Company B from Comapny A which will not work..The EIGRP 200 configs on Company-B and Company-A-R1 are global routing table specific
Also your BGP config on Company B router confirms that Subnet 192.168.200.0/30 is in VRF
  network 192.168.200.0 mask 255.255.255.252--VRF Specific Advertisement
company B#ping 192.168.200.5--From Company B we can ping global IP of Company-A-R1
Varma
Hi Varma,
I understand that the  EIGRP 200 between the companies should talk using the global outing tables[EIGRP], my question is How can we make the subnets available both in BGP table and EIGRP table? How can we make the directly/static connected routes avilable to both routing table?
Hi Blach
router eigrp 200
no auto-summary
no auto-summary
exit-address-family
Varma
Thanks for your response Varma, You perfecly understood the scenario, Based on your advise if I make Company B EIGRP 200 into VRF node, I have to make Company A R1 also into VRF node, which I cannot  make it!! Do we have any other way of redistributing  the routing in to both EIGRP[Gloabal] and BGP tables?[VRF]
Hi Blach
E.G)
On Company B
router eigrp 200
redistribute static
Varma
Thanks for the response, I will try both the options and see how it goes, appreciate your response.
VIP Super Bronze
I am not sure, what you are trying to accomplish with vrf here.  You have an interface in global on one router (router a)and an interface in vrf on the router router (router b).  On router b you are trying to reach the global routing table.  Why can't peer both routers using global routing table. vrf is usually used for path isolation.  If you have one physical network with multiple customers on it, it would make sense to provide path isolation for each customer, so they don't see each others' route table.  In your case, you the 2 companies that have merged to be one, and unless I am missing something, I don't see end-to-end path isolation.
Thank for the Reply, I have 60+ customers on Router B seperating ther traffic using VRF[as you mentioned for isolation]. I just gave a Loopback as an example.Sorry I should have provided this info earlier.And I have to make only 30 of the customers traffic available to Company A and viceversa.
1192
