remote access MPLS/VPN issue
I am running some tests with Remote Access Dial In MPLS/VPN. First I configured the VPDN to authenticate locally on the VG(LNS) and everything was OK. Then I configured to authenticate and manage IP addressing on a Radius Server in the following way:
I configured virtual-profiles with virtual-template so the Radius Server gives me the following commands through AVpairs:
lcd:interfaceconfig#1=ip vrf forwarding VRFname
lcd:interfaceconfig#2=ip unnumbered loopback 0
lcd:interfaceconfig#3=peer default ip address pool <pool name>
whereas in the virtual template I only have the following configuration:
interface Virtual-Template1
no ip address
no peer default ip address
ppp authentication chap callin
ppp multilink
And everything works OK!!!
Then the customer wants the radius server to manage the Ip addressing, so I mantain the virtual-template as before, and I change the radius AVpairs to:
lcd:interfaceconfig#2=ip vrf forwarding VRF
lcd:interfaceconfig#3=ip add x.x.x.x 255.255.255.255
And it never works... so I try to enter these commands manually and I notice that the virtual template interface does not accept the /32 mask.
Is there a way to change that?. In case I can not assign the IP address with this mask, what is the best approach to the radius to assign the IP address.
Thanks for your help
Regards!
1 REPLY
Bronze
Re: remote access MPLS/VPN issue
I think the /32 mask is valid only on a loopback interface since there cannot be any other host on such an interface. Probably you will have to find a workaorund that uses a loopback interface in this case.
141
