Community Member
Removal of Ima Group
I have created and ima group "ATM1/ima1" which shows up in the config as
interface ATM1/ima1
no ip address
shutdown
no atm ilmi-keepalive
I would like to remove (no int atm1/ima1) it but when I do the router says "cannot remove physical interfaces. How do I get rid of it?
Bronze
Re: Removal of Ima Group
If you have the 'ima-group' command under the physical ATM interfaces, remove them and then try to remove the IMA interface. See this link for more info :
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087a7d.html
Community Member
CSCds56866
Cisco IOS software does not allow for the removal of a virtual IMA interface. The following error message is appears on the screen: "% Removal of physical interfaces is not permitted." Currently, the only workaround is to reload the router. If a "write memory" has not been performed, then the reload will clear the virtual IMA interface.
384
