Community Member
RIP to CE (L2TP VPDN DSL Connection)
Just attempting to have CE advertise the LAN subnet to PE, without success.
On CE(No NAT enabled), I currently have:
interface Ethernet0
description LAN
no keepalive
router rip
version 2
redistribute static
network 192.168.1.0
#show ip rip database
0.0.0.0/0 auto-summary
0.0.0.0/0 redistributed
[1] via 0.0.0.0,
192.168.1.0/24 auto-summary
192.168.1.0/24 directly connected, Ethernet0
Then on PE:
router rip
version 2
address-family ipv4 vrf TEST10
redistribute bgp 17766 metric transparent
network 10.0.0.0
network 192.168.1.0
no auto-summary
version 2
exit-address-family
#show ip rip database vrf TEST10
10.0.0.0/8 auto-summary
10.0.0.0/24 directly connected, Loopback10
10.0.2.1/32 directly connected, Virtual-Access7
10.0.2.2/32 directly connected, Loopback11
10.0.3.0/24 redistributed
[1] via 203.149.76.248,
10.0.5.0/24 redistributed
[1] via 203.149.76.249,
10.0.6.0/24 redistributed
[1] via 203.149.76.250,
10.0.7.0/24 redistributed
[1] via 203.149.76.247,
PE can successfully get to CE WAN (10.0.2.1), but not the CE LAN.
MB
Re: RIP to CE (L2TP VPDN DSL Connection)
you need to include the PE-CE network into your RIP processes. The config should look like:
CE:
router rip
version 2
redistribute static
network 192.168.1.0
network 10.0.0.0
no auto-summary
PE:
router rip
version 2
redistribute bgp 17766 metric 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
version 2
exit-address-family
router bgp 17766
redistribute rip
no synchronization
no auto-summary
exit-address-family
I would also advise you to use a fixed metric, otherwise you might encounter problems, when redsitributing routes with a BGP MED larger than 15, because RIP will try to use this as hop count and find it to be "unreachable".
A helpful command for troubleshooting in this context is "show ip protocols vrf TEST10" on the PE (without vrf on the CE). You should see the other side as routing information source.
Hope this helps! Please rate all posts.
Regards, Martin
Community Member
Thanks for the response - I now have what you suggested, but PE is still not receiving the CE LAN subnet:
PE:
ip vrf TEST10
rd 17766:10
route-target export 17766:10
route-target import 17766:10
maximum routes 256 75
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
version 2
exit-address-family
router bgp 17766
redistribute connected
redistribute static
redistribute rip
no auto-summary
no synchronization
exit-address-family
CE:
router rip
version 2
redistribute static
network 10.0.0.0
network 192.168.1.0
no auto-summary
Then CE Rip:
test# show ip rip database
[1] via 0.0.0.0,
10.0.2.1/32 directly connected, Dialer1
10.0.2.2/32 directly connected, Dialer1
PE Rip:
[2] via 203.149.76.248,
[2] via 203.149.76.249,
[2] via 203.149.76.250,
[2] via 203.149.76.247,
And I'm not seeing the CE as a routing info source:(Do I have to enable rip on my VirtualTemplate?)
#show ip protocols vrf TEST10
Routing Protocol is "bgp 17766"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
IGP synchronization is disabled
Automatic route summarization is disabled
Redistributing: connected, static, rip
Maximum path: 1
Routing Information Sources:
Gateway Distance Last Update
203.149.76.247 200 1w2d
203.149.76.245 200 3w4d
203.149.76.250 200 1w2d
203.149.76.248 200 2w5d
203.149.76.249 200 3w4d
Distance: external 20 internal 200 local 200
Routing Protocol is "rip"
Sending updates every 30 seconds, next due in 25 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Redistributing: bgp 17766, rip
Default version control: send version 2, receive version 2
Interface Send Recv Triggered RIP Key-chain
Loopback10 2 2
Loopback11 2 2
Maximum path: 4
Routing for Networks:
10.0.0.0
192.168.1.0
Distance: (default is 120)
my assumption was, that the network between CE and PE (namely the interface IPs) are in the range 10.0.0.0/8.
In case you have a virtual template starting connectivity between PE and CE then you should include it´s IP address as network statement.
The network statements in RIP identify the interfaces on which RIP updates should be sent and which networks to include in the updates. So make sure that the PE-CE interfaces are included.
Regards, Martin
Community Member
Thanks again for your assistance with this.
I have added the Loopbacks IP to rip:
PE:
interface Virtual-Template1
description L2TP-1 Termination
ip unnumbered Loopback1
qos pre-classify
ppp authentication chap callin
interface Loopback1
description BNE-LNS-1 Interface
ip address 203.149.76.243 255.255.255.255
router rip
version 2
network 10.0.0.0
network 192.168.1.0
network 203.149.76.0
no auto-summary
version 2
exit-address-family
but still no joy in rip:
Maximum path: 1
203.149.76.250 200 1w3d
Sending updates every 30 seconds, next due in 20 seconds
Loopback10 2 2
Loopback11 2 2
Maximum path: 4
10.0.0.0
192.168.1.0
203.149.76.0
Note: If I add the following static route, I can successfully get to CE LAN:
ip route vrf TEST10 192.168.1.0 255.255.255.0 10.0.2.1
Hall of Fame Super Silver
you have linked virtual-template1 to loopback1, did you mean loop10 instead ?
Loop1 is a backbone interface from your configuration:
interface Loopback1
in the RIP database for VRF TEST10 loop10, loop11 and Virtual-Access 7 are listed.
Been loop1 in the global routing table the network command under rip af vrf TEST10 is not working.
For this reason RIP messages from CE router are probably ignored and so the PE cannot learn the Customer LAN network
Hope to help
giuslar
Community Member
Thanks for the reply - Loop10 is being assigned to DSL Int upon connection:
Radius reply attribute:
lcp:interface-config=ip vrf forwarding TEST10 \nip unnumbered Loopback10
interface Loopback10
ip address 10.0.0.1 255.255.255.0
So how do you suggest I modify my config so that the PE can talk rip to CE?
MB
Silver
hi bell,
On the PE do u have any interface with same ip subnet of CE LAN(192.168.1.0).
If not why ur advertising that n/w from PE too.(network 192.168.1.0). Try by removing that line from rip on PE.
Hope this will help,
Rgs.
I would try to link virtual-template 1 to Loop10 instead of Loop1 so that both Virtual-Access 7 and Virtual-Template 1 are members of VRF TEST10.
Interface Virtual-Access is derived from Virtual-template 1 and from RADIUS reply and currently VT1 is a member of global routing table and the Virtual-Access is member of VRF.
This mismatch could cause the problem you see
hope to help
giuslar
Community Member
Unfortunately I cannot link virt template to loop10 - This virt template is used for all vpdn connections (vrf + non-vrf)
OK I see,
But IF you are using the Virtual-Template 1 just as a Front End for PPP CHAP authentication and RADIUS reply provides L3 info for both VRF and non VRF users
THEN I would try to use "no ip address" within Virtual-template 1 configuration to give it a neutral role.
I tried this on a similar context of ISDN direct access to MPLS VPN (without using L2TP), with some users members of VRFs and other that are in the global table and for me worked (I was using eBGP sessions actually for PE-CE communication) also at the same time on multiple clients.
In my case virtual-template was without IP address and all L3 info was provided by the RADIUS server.
Another idea could be to try to use the neighbor command within rip address-family vrf TEST10 on the PE router and on the CE router rip process just to avoid any issue with multicast on the PPP over L2TP link ( RIP updates are TX/RX as unicast)
hope to help
giuslar
320
