12-19-2006 04:01 PM
anyone know how many(quantity) different RT's you can import into 1 central VRF. What the limitation is?
12-20-2006 05:20 AM
I do not think there is a hard limit. The limit is probably more tied to the resources available on the router and the config size.
Hope this helps,
12-20-2006 08:57 AM
import can be "any number", I myself tried more than 500 in a lab environment with no problem. RT export is different in that you may only have up to 128 extended communities in a single BGP update and additionally a maximum BGP update size of 4096 Bytes exists. Whichever limit you hit first will prevent you from announcing a VPNv4 prefix.
Hope this helps! Please rate all posts.
Regards, Martin
