Routing Between CE Routers
Do I need to establish BGP Peering between two PE's that connect to different CE's within the same VRF?
I see the routes on one of the PE's in the VRF's routing table, but not the other. Not sure why.
I would think that I first need to see the routes advertised routers in the PE's before I can even think about having the routes end up in the CE's.
What troubleshooting steps do I need to take?
Is there a troubleshooting doc that I can reference?
  • MPLS
Re: Routing Between CE Routers
Mark,
Yes, you do need to have a BGP session between the two PEs under the VPNv4 address family (either direct or through a route reflector).
This session should be established using the IP address of the loopback interface on each PE. Also to avoid any issues, make sure that the IP address of the loopback interface is configured as a /32.
So I have the PE's configured for BGP, attempting to make an IBGP connection but not being successful. I have removed and readded the config. The BGP state is staying active.
The route for PE2 appears in the routing table for PE1 via OSPF and vice versa.
Here is the network diagram
PE1->MPLS-BB1->MPLS-BB2->PE2
When I do a trace for PE2 from PE1 it stops at MPLS-BB1 and when I do a trace for PE1 from PE2 it stops at MPLS-BB2.
Here is the config:
PE1
interface Loopback0
ip address 68.2.0.1 255.255.255.255
router ospf 1
router-id 68.2.0.1
log-adjacency-changes
redistribute bgp 65000
network 68.0.0.0 0.255.255.255 area 0
router bgp 65000
no synchronization
bgp log-neighbor-changes
redistribute connected
redistribute ospf 1
neighbor 68.2.0.3 remote-as 65000
neighbor 68.2.0.3 update-source Loopback0
no auto-summary
address-family vpnv4
neighbor 68.2.0.3 activate
neighbor 68.2.0.3 send-community extended
exit-address-family
**MPLS-BB1**
router ospf 1
router-id 68.1.0.1
**MPLS-BB2**
router eigrp 2
passive-interface default
no passive-interface GigabitEthernet1/0/1
network 10.0.0.0
no auto-summary
router ospf 1
router-id 68.1.0.2
redistribute eigrp 2
default-information originate
**PE2**
interface Loopback0
ip address 68.2.0.3 255.255.255.255
router ospf 1
router-id 68.2.0.1
router bgp 65000
no synchronization
redistribute ospf 1
no auto-summary
exit-address-family
Mark,
1. It looks like you are using the same ospf router id on both PE1 and PE2 (68.2.0.1). They should definitely be different.
2. On PE2, the bgp neighbor address should be 68.2.0.1 rather than 68.2.0.3, which is the local address. This is probably just a typo.
3. You should not redistribute ospf in bgp (redistribute ospf 1) on both PEs.
I have to call ID10T error on that one. I pasted the config from PE1 and pasted it as the config for PE2. I apologize for wasting your time on that turn.
I have cleaned up the config with your guidance. The situation now is that I can ping 68.2.3.2 from MPLS-BB1 but not the Loopback on PE2. From PE1, I can't ping 68.2.3.2 or the Loopback of 68.2.0.3 of PE2. The same holds true for MPLS-BB2 and PE1, I can ping 68.2.1.2 but not the Loopback of 68.2.0.1.
Do I need to place redistribute connected on all of the ospf and bgp instances in the network?
Do I need to redistribute bgp into ospf?
Here are the latest configs:
*****PE1*****
router ospf 1
router-id 68.2.0.1
router bgp 65000
no synchronization
no auto-summary
exit-address-family
address-family ipv4 vrf vpn-mtb
neighbor 68.139.201.30 remote-as 1
neighbor 68.139.201.30 activate
neighbor 68.139.201.30 as-override
no auto-summary
no synchronization
exit-address-family
*****MPLS-BB1*****
interface Loopback0
ip address 68.1.0.1 255.255.255.255
interface FastEthernet0/0
ip address 68.1.1.1 255.255.255.252
duplex auto
speed auto
tag-switching ip
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
ip address 68.2.1.1 255.255.255.252
duplex auto
speed auto
tag-switching ip
interface FastEthernet2/1
ip address 68.2.2.1 255.255.255.252
duplex auto
speed auto
tag-switching ip
router ospf 1
router-id 68.1.0.1
*****MPLS-BB2*****
interface Loopback0
ip address 68.1.0.2 255.255.255.255
interface FastEthernet1/0/1
no switchport
ip address 68.2.3.1 255.255.255.252
no snmp trap link-status
mpls ip
interface FastEthernet1/0/2
no switchport
ip address 68.2.4.1 255.255.255.252
mpls ip
******truncated
router eigrp 2
network 10.0.0.0
no auto-summary
router ospf 1
router-id 68.1.0.2
*****PE2*****
interface Loopback0
interface Ethernet0/0
ip address 68.2.3.2 255.255.255.252
half-duplex
tag-switching ip
interface Ethernet0/1
ip vrf forwarding vpn-mtb
ip address 152.162.21.77 255.255.255.252
full-duplex
router ospf 1
router-id 68.2.0.3
router bgp 65000
no synchronization
neighbor 68.2.0.1 remote-as 65000
neighbor 68.2.0.1 update-source Loopback0
no auto-summary
neighbor 68.2.0.1 activate
neighbor 68.2.0.1 send-community extended
exit-address-family
neighbor 152.162.21.78 remote-as 1
neighbor 152.162.21.78 activate
neighbor 152.162.21.78 as-override
no auto-summary
no synchronization
exit-address-family
Mark,
Thanks for the update. The lack of full IP connectivity is probably due to an ospf misconfiguration.
Are the ospf adjacencies up between all neighbors? Could you also check that both PE1 and PE2 are advertising their loopback interface IP address in their own router LSA (show ip ospf database router self-originate).
You should not need to redistribute BGP into ospf or vice versa. You should not need to redistribute the connected routes either as the network statement configured for ospf includes all of the core interfaces, including the loopback addresses.
Could you also attach the full configs for PE1, MPLS-BB1, MPLS-BB2 and PE2.
Harold,
Here is the info you requested.
PE1#show ip ospf database router self-originate
OSPF Router with ID (68.2.0.1) (Process ID 1)
Router Link States (Area 0)
LS age: 32
Options: (No TOS-capability, DC)
LS Type: Router Links
Link State ID: 68.2.0.1
Advertising Router: 68.2.0.1
LS Seq Number: 80000051
Checksum: 0xB2B7
Length: 48
Number of Links: 2
Link connected to: a Stub Network
(Link ID) Network/subnet number: 68.2.0.1
(Link Data) Network Mask: 255.255.255.255
Number of TOS metrics: 0
TOS 0 Metrics: 1
Link connected to: a Transit Network
(Link ID) Designated Router address: 68.2.1.1
(Link Data) Router Interface address: 68.2.1.2
TOS 0 Metrics: 1
PE2#show ip ospf database router self-originate
OSPF Router with ID (68.2.0.3) (Process ID 1)
LS age: 7
Link State ID: 68.2.0.3
Advertising Router: 68.2.0.3
LS Seq Number: 80000009
Checksum: 0xA2FC
Length: 48
Number of Links: 2
(Link ID) Network/subnet number: 68.2.0.3
TOS 0 Metrics: 1
(Link ID) Designated Router address: 68.2.3.1
(Link Data) Router Interface address: 68.2.3.2
TOS 0 Metrics: 10
Thanks.
Mark,
A couple of things.
1. CEF is not enabled on MPLS-BB2. This is probably not the cause of the lack of IP connectivity but will cause MPLS not to work later on.
2. Eigrp is still enabled on MPLS-BB2. You should probably disable it.
3. Could you run a "show ip ospf data" on PE1 and PE2 and post the results.
I added CEF on MPLS-BB2.
I removed EIGRP from BB2.
Here is the show ip osfp data
*****PE1*****
Link ID ADV Router Age Seq# Checksum Link count
68.1.0.1 68.1.0.1 303 0x80000052 0x000C6A 4
68.1.0.2 68.1.0.2 1664 0x80000009 0x004E5E 4
68.2.0.1 68.2.0.1 935 0x80000053 0x00AEB9 2
68.2.0.3 68.2.0.3 326 0x8000000C 0x009CFF 2
Net Link States (Area 0)
68.1.1.1 68.1.0.1 558 0x80000007 0x007BA0
68.2.1.1 68.1.0.1 1569 0x80000005 0x0071AB
68.2.3.1 68.1.0.2 1664 0x80000005 0x007B9B
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
0.0.0.0 68.1.0.2 1921 0x80000008 0x00B2B1 1
*****PE2*****
68.1.0.1 68.1.0.1 413 0x80000052 0x000C6A 4
68.1.0.2 68.1.0.2 1772 0x80000009 0x004E5E 4
68.2.0.1 68.2.0.1 1047 0x80000053 0x00AEB9 2
68.2.0.3 68.2.0.3 432 0x8000000C 0x009CFF 2
68.1.1.1 68.1.0.1 668 0x80000007 0x007BA0
68.2.1.1 68.1.0.1 1679 0x80000005 0x0071AB
68.2.3.1 68.1.0.2 1772 0x80000005 0x007B9B
0.0.0.0 68.1.0.2 2029 0x80000008 0x00B2B1 1
Mark,
This looks good to me. Can you do a "show ip route" on both PE1 and PE2. Can you also trace from PE1 to PE3 loopback address and vice versa and post the result.
497
