RSVP problem
I connected Cisco3640 to IXIA,and sending RSVP messages from IXIA but geting the following error.
*Apr 11 06:55:49.974: %RSVP-3-BAD_RSVP_MSG_RCVD_TYPE: RSVP Message had a bad typ
e: 20
-Traceback= 0x603F4E74 0x60B61928 0x60B709A4 0x60B5854C 0x60B58AEC 0x604F0574 0x
604F0558
*Apr 11 06:55:49.978: %RSVP-3-IP_HDR: 46C00032 A3D70000 3F2E62AE C0A82F02 C0A82F
01 94040000 10140000 4000001A
*Apr 11 06:55:49.978: %RSVP-3-MSG_1: 10140000 4000001A 00060001 0000000C 160100
00 00010000 0000000F 00000401
*Apr 11 06:55:49.978: %RSVP-3-MSG_2: 00040404 04040000 C0A82F02 FFF60003 000100
04 00000001 00000000 00000000
What will be the problem ?
1 REPLY
Re: RSVP problem
Ganpat,
This error message simply says that the IOS you are running doesn't support the RSVP message type that was received. In this particular case, the message type is 20, which refers to an RSVP hello message.
The tracebacks should not be generated though. CSCea45107 cleans it up and only generates a unsupported message type warning message.
If you want to get rid of these error messages, I would recommend disabling RSVP hello on the IXIA box.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
1302
