Running MPLS on CISCO XR IOS
I have a CISCO XR 12010 router and i want to run LDP Adjacency on the mgmtEth 0/0/CPU0/0 interface available on the RP Slot. Is is possible to run LDP on this interface as i don't see any option to select the management ethernet interface under the MPLS LDP process.
1 REPLY
Hall of Fame Super Silver
Re: Running MPLS on CISCO XR IOS
Hello Amit,
management interface is to be used only for management: it misses forwarding ASIC chips so using it loads the main cpu heavily (process switching).
I strongly recommend to use something else like the GE port on the SPA (see your other thread)
Hope to help
Giuseppe
215
