Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Silver
Specific VPNs through TE Tunnel
I want to setup a Traffic Engineering tunnel across two PEs. The challenge is that I wish that some specific VPN use this tunnel, while other VPN use another route. In case of failure though, the traffic should failover. How do I specify which VPN can or cannot use the TE Tunnel?
1 ACCEPTED SOLUTION
Re: Specific VPNs through TE Tunnel
You could use the "bgp next-hop" command under a specific "ip vrf " to specify what next hop is used when advertising prefixes belonging to that VRF into VPNv4. By using a different NH you could forward traffic for this VRF via a specific tunnel. If the tunnel ever goes down, traffic to that NH would then be forwarded using the LSP built via LDP.
Let me know if I answered your question,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Silver
Oops, sorry Harold, I never mentioned that this solved my problem. I noticed though that only loopbacks can be used as the BGP next hops. Any workaround this.
Not really. What is the issue with using a loopback interface as the BGP next-hop.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Silver
No issue actually, just thinking of scenarios.
If I have multiple TEs, and I want a differentiated service such that different traffic types can use different tunnel. And this in an MPLS VPN scenario?
Do you have any ideas?
138
