Telnet and Telnet
guys,
I got a small problem but it is very amusing.
I have 7513 runing MPLS for VPN with IOS 12.2.14S5.
Now the device can not be able to telnet even form the device itself.
No access-list and access clas configured.
When i do sh line and sh user there is one line active but don't know whre it is come from.
and i cant kill this line.
PE-UPTGDL75_01#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 637 149 4/1531109147 -
1 AUX 9600/9600 - - - - - 0 0 0/0 -
2 VTY - - - - - 844 0 0/0 -
* 3 VTY - - - - 1 322 0 0/0 -
4 VTY - - - - - 99 0 0/0 -
5 VTY - - - - - 47 0 0/0 -
6 VTY - - - - - 28 0 0/0 -
PE-UPTGDL75_01#sh user
Line User Host(s) Idle Location
* 0 con 0 praweda idle 00:00:00
3 vty 1 idle 1w0d 12.220.62.102
Bronze
Re: Telnet and Telnet
Reg who's logged on.
Source ip 12.220.62.102 has been allocated by AT&T
(7018) to Insight Communications Company INSIGHT
You can check with those guys.
AT&T WorldNet Services ATT (NET-12-0-0-0-1)
12.0.0.0 - 12.255.255.255
Insight Communications Company INSIGHT-12-220-62-0-EVANSVILLE (NET-12-220-62-0-1)
12.220.62.0 - 12.220.63.255
route-server>sh ip bg 12.220.62.102
BGP routing table entry for 12.0.0.0/8, version 22
Paths: (20 available, best #9)
Not advertised to any peer
7018, (received & used)
12.123.45.252 from 12.123.45.252 (12.123.45.252)
Origin IGP, localpref 100, valid, external
Community: 7018:1000
How do you access the box then?
1)
If it is by console, do you have under
line con 0
transport output telnet
If you don't have it you won't be able to telnet anywhere ;-)
2) does cle line vty 1
work?
If it doesn't try to set
exec-timeout 10
session-timeout 10
under line vty 0 x
3) if that in 2) isn't enough - try to add:
service tcp-keepalive-in
service tcp-keepalive-out
Hope this helps.
Zvezdelin Vladov
136
