TELNET in MPLS
How can i telnet in MPLS, Please let me know the syntax.
Thanks & regards,
Srinivas.S
Re: TELNET in MPLS
telnet a.b.c.d /vrf VPN_EXAMPLE
Re: TELNET in MPLS
thanks for the reply.
I have been trying the same telnet a.b.c.d /vrf VPN_EXAMPLE but iam not able to telnet, there is no access list restrictions in the router for line vty. is there any other way.
regards,
Srinivas.S
Bronze
Re: TELNET in MPLS
Check if the prefix is in the vrf table ?
Are u redist Connected for that VRF
Re: TELNET in MPLS
PE>sh ip vrf
Name Default RD Interfaces
abc_xyz 123:2004 Serial4/6
Re: TELNET in MPLS
Can you telnet the device itself but not VRF?
Re: TELNET in MPLS
Iam able to ping and trace but not able to telnet with and without VRF.
Thanks & Regards,
Srinivas.S
Re: TELNET in MPLS
Try this:
telnet a.b.c.d /vrf VPN_EXAMPLE /source-interface OUTGOING INTERFACE
Re: TELNET in MPLS
I am sure that I have seen this in the past, on some older versions of IOS I could ping from a VRF but was not able to telnet out of it... your command looks good to me .. might just be an IOS thing ??
1236
