Tracking ATM PVC enabled with MPLS
We are trying to identify a method where the ATM sub-interface enabled with Mpls shows line protocol UP but the ip reachability to the other side of the PVC is not there due to some issues in the ATM backbone.
Can we would be able to use the track 1 interface ip routing would help us . If so ,when it identifies the ip reachability on the PVC is done,will it log into the router or can it send to the management station. We are trying to deploy the same in 7600 switches running 12.2(18)SXF4.
Anantha Subramanian Natarajan
Re: Tracking ATM PVC enabled with MPLS
Anantha,
Your routing protocol should detect the fact that something is going wrong in the ATM core, right?
Regerds,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi Hritter,
You right and we actually worried about a situation where the layer 3 (OSPF) neighborship went down but still the layer 2 ATM PVC Line protocol status saying up.
You may want to think of using OAM for PVC management. As it sends Loopback cell echoes between the end points and upon failure to receive the configured Echo Cell replies it brings the corresponding PVC down.
This may as well prevent blackholing of the traffic till the OSPF adjacency is bought down due to the failure.
Here is a link on this feature:
http://www.cisco.com/warp/public/121/oam.html
HTH-Cheers,
Swaroop
Swaroop,
In my opinion, it would make more sense to reduce the ospf hello timer. I have seen people using the OAM feature when no routing protocols were involved.
Cheers,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Hi Harold,
Yes, I agree, thats another way of doing it.
But if particularly if its needed to get the line protocol down for alarms/logs purpose as a proactive measure to react in time. This could be used as well.
Swaroop
234
