Traffic Rates on RSP720 for 128bytes
Hi all,
Hi have installed a network made of 7609-S with RSP720 and ES-20G line cards with 12.2.33SRB3. We networ is running mpls and we have several EPL configuring on the router to make stress test. On one test we were sending 64b frames in to the EPL and we notice that the router only swiths 20Mpps that represent a 6.XGbits full duplex of bw consume. Then we change the frame to 128byte to see the beavihor and we notice that the router only switch 12,6Mpps and 7.4Gbits full duplex. I expect to have high values around the 20Mpps or 9,XGbits. For frames start at 256bytes the BW consume reach 9,8Gbits and the Mpps start to decrease as normal. The problem is for frame with 128bytes.
Can any one point me to same official test where i can compare this results.
Many thanks
1 REPLY
Re: Traffic Rates on RSP720 for 128bytes
Nothing official, but I have the following results myself for you to compare:
64 byte - 7600Mbps 11310054 frames/sec
128 byte - 8500.1 7179158 frames/sec
256 byte - 9100.0 4121384 frames/sec
512 byte - 9500.0 2232152 frames/sec
1024 byte - 9700.0 1161404 frames/sec
1280 byte - 9800.0 942312 frames/sec
1518 byte - 9800.0 796492 frames/sec
231
