Community Member
Trouble setting up remote access vpn
26-Jul-2013 09:41 (in response to ciscomoderator)
Re: Ask the Expert: Understanding MPLS L3VPN: concepts, terminology, control and data plane call flow
Keddian Gilbert
Concerning the nature of my problemes, am trying to setup a remote access vpn to my 3620 series router; however
am not able to use the command prompt because of my limited knowledge of the necessary commands. to configure a remote VPN conniction.
I checked out several instructions on the internet but all of them used GROUP PROFILE and the TUNNEL command in their config
which my router does not support. All I want is the specific configuration for this version IOS seeing  it differs in configuration.
I cant use SDM. My router does not have enough memory to accept it.
Here is an out put of a SHOW VER  command
digix-lan>sh ver
IOS (tm) 3600 Software (C3620-JK9S-M), Version 12.2(29), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 11-May-05 12:54 by kellmill
Image text-base: 0x60008930, data-base: 0x61598000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3620-JK9S-M), Version 12.2(29), RELEASE SOFTWARE (fc3)
digix-lan uptime is 2 days, 1 hour, 42 minutes
System image file is "flash:c3620-jk9s-mz.122-29.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 3620 (R4700) processor (revision 0x81) with 60416K/5120K bytes of memory.
Processor board ID 10707060
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
4 Ethernet/IEEE 802.3 interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
I really need this help sir! THANK YOU much
310
