Community Member
Understanding Fragmentation in MPLS
We will be converting from a Frame relay to MPLS network. We will be implementing Voice on this new MPLS network. Currently we have FRTS set up between remotes and head-end to insure proper Fragmentaion sizes (among other things). How does this work in an MPLS implementation? IF my head-end is a DS3 sending 1500 byte frames out and my remotes vary from 128K to 512K how do I fragment properly to these small size remotes. The remotes will continue to us frame-relay for the last mile.
Community Member
Re: Understanding Fragmentation in MPLS
Please, explain more.
As for example explain the would-be setup.
It is not clear what you would like to do.
Also you are mixing the things IMHO.
Frame-relay fragmentation?
MPLS doesn't do any fragmentations. Doesn't support it. It is just a switching method.
How you deliver traffic/voice from X to Y
is another question. Of course you can
go through MPLS core, but....
Explain more please.
Community Member
I guess you answered my basic question. Voice requires fragmentaion on low speed links to reduce jitter. This can be accomplished in Frame-Relay. If MPLS will not allow fragmentation it may reduce quality in a voice deployment.
Community Member
If you have a MPLS core you can do this:
(1) (2) (3) (4) (5)
FR----FR-------MPLS CORE------FR-------FR
That is l2connect.
It basically encapsulates the L2 frames over
the MPLS core.
You can do FR frag at the edge (1) and (2)
go over l2connect (AToM=Any transport over MPLS)
over (3) and go to (5).
(2)&(4) are an MPLS edge device.
You can have some prioritizations, on the
l2connect.
http://www.cisco.com/en/US/customer/tech/tk436/tk428/technologies_q_and_a_item09186a008009d4e3.shtml
Community Member
Makes sense to me. However, AT&T and MCI will not support FRF.12 until later 2004 in their MPLS deployments regardless of the access type.
283
