VPN Hub and Spoke configuration
Hi all,
I'm trying to understand a config.
This is a Hub and Spoke VPN over MPLS.
There is a PE with a VRF configured as the Hub.
There are other PEs with several VRFs acting as the Spokes.
Everything looks clear to me except for a detail, in the PEs where the spokes are configured there is a kind of major VRF also configured... this VRF inport and export the same than the rest of the spoke VRFs... so... I would like to know the reason of configuring that VRF, I thought that It was enough just with the spokes.
Thanks a lot in addvance,
Re: VPN Hub and Spoke configuration
can you post the configs
Narayan
Sorry for delaying, here is the config:
ip vrf VPN_A
description "Loop350 del PE como SPOKE de la VPN A (Estrella)"
rd 65003:1103
export map Marcado_prefijos_VPN_ADM
route-target import 65003:1000011
route-target import 65001:1000011
ip vrf VPN_A_A016
description "Spoke de la VPN_A para la sede A016.
rd 65003:11031703
143
