Community Member
what are the pros and cons using ospf as the PE/CE protocol
pros and cons using ospf as the PE/CE Protocol
Silver
Re: what are the pros and cons using ospf as the PE/CE protocol
Well in short,
pros:
well deployed protocol with good user experience
fast convergence
no redistribution required on ce side
cons;
type 1 & 2 routes (O) from one site are known as type 3 summary routes (OIA) in the other site
you need a sham link configured on the pe routers to get the routes as type1&2 at each remote site
If was deploying mpls vpn, i would use either ospf or bgp as pe/ce protocol.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/ospfshmk.html#wp1024995
LR
Community Member
Thanks for reply ,
Under cons you have explained about Intra route(sham link)
any explanation in case of VPN TAG and Down bit .
Silver
With regard to down bit, it is automatically set by the PE when redistributing BGP routes into ospf as type 1/2/3. The tag field is copied from the bgp as number, into the tag field for type 5/7 (external) routes.
These are both to ensure that a route redistributed into ospf from bgp, cannot go back into bgp on another pe at same site.
This is all done automatically, so you dont need to worry about them.
HTH,
LR
530
