xconnect on SVI interface ES Cards on 7606
Is it possible to configure xconnect from an SVI interface, when your core facing cards are RSP-720?
I have configured it:
interface Vlan290
no ip address
xconnect 10.10.136.129 37123712 encapsulation mpls
end
It does not come up:
PE4#sh mpl l2transport vc
Local intf Local circuit Dest address VC ID Status
Vl290 Eth VLAN 290 10.10.136.129 37123712 DOWN
PE4#sh mpl l2transport vc 37123712 det
PE4#sh mpl l2transport vc 37123712 detail
Local interface: Vl290 up, line protocol up, Eth VLAN 290 up
Interworking type is Ethernet
Destination address: 10.10.136.129, VC ID: 37123712, VC status: down
Output interface: none, imposed label stack {}
Preferred path: not configured
Default path: no route
No adjacency
Create time: 00:00:49, last status change time: 00:00:03
Signaling protocol: LDP, peer 10.10.136.129:0 up
Targeted Hello: 10.10.136.131(LDP Id) -> 10.10.136.129
Status TLV support (local/remote) : enabled/not supported
Label/status state machine : remote ready, LndRru
Last local dataplane status rcvd: no fault
Last local SSS circuit status rcvd: AC DOWN(rx,tx faults)
Last local SSS circuit status sent: no fault
Last local LDP TLV status sent: no fault (withdrawn)
Last remote LDP TLV status rcvd: not sent
MPLS VC labels: local unassigned, remote 340
Group ID: local unknown, remote 0
MTU: local unknown, remote 1500
Remote interface description: ** Test PW with PE4 ES SVI int **
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, seq error 0, send 0
Although when I use a physical interface it comes up?
RSp720 does not support it??
Re: xconnect on SVI interface ES Cards on 7606
I moved my core facing link to ES card instead of RSP 720 and it works.
PE4#sh mpls l2transport vc
Vl290 Eth VLAN 290 10.10.136.129 37123712 UP
but now i am thinking what we can use the RSP-720 gige ports for.
Hall of Fame Super Silver
Hello Atif,
I had that same doubt that ES card has to have the core facing interface.
management :)
Hope to help
Giuseppe
Also in QoS RSP720 does not support prirotity queueing for real time traffic... not sure why we don't have all this in this latest SUP for 7600.
428
