Silver
xconnect problem
we are having PE-PE xconnect.There sessions are established last five weeks.But now there session is brraken up.And now we are not able to start new xconnect session between pe-pe.Can anyone provide the solution.
Re: xconnect problem
Shivlu,
Can you include a "show mpls l2 vc det" from both PEs.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi Harold, I didnt see your reply.
Anyways,
Cheers,
Swaroop
No problem Swaroop.
Cheers,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Silver
i am forwarding my configuration of both PE'S.
IST PE:-
interface FastEthernet0.801
description #### CE MPLS INTERFACE ####
encapsulation dot1Q 801
no snmp trap link-status
no cdp enable
xconnect x.x.x.x 801 encapsulation l2tpv3 pw-class shivlu
end
Second PE:-
interface GigabitEthernet0/2.801
description #### VARANASI MPLS INT ####
no cdp enable
end
now when i run the command at pe2 i got the output like the given
VARANASI_PGCIL#sh l2tun session
%No active L2F tunnels
L2TP Session Information Total tunnels 2 sessions 3
LocID RemID TunID Username, Intf/ State Last Chg Uniq ID
Vcid, Circuit
3610 12208 30621 246, Fa0.246:246 est 01:02:36 2
3849 0 49847 890, Fa0.890:890 wt-tnl 00:00:01 129
3851 0 49847 801, Fa0.801:801 wt-tnl 00:00:00 58
my tunnels are always in the wt-tnl state.But this session is already established for 3 weeks not it got down and not able to up again.It is happening the same way with the clients.For the solution i have to migrate the clinet to another router where is worls fine.
The remote id is always 0 at one end.As i think that my core 7200 series router is not able to generate the tunnels and not assigning the local id number.
My hardware details are given below:-
7200 here i am getting problem
2811
It looks like the l2tpv3 packets might not be getting from one PE to the other.
Is it possible to run a "debug xconnect"
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Sincerly you should open a TAC case at your earliest. Since its in prodcution and a working config has stopped working.
In the meanwhile when you open the case, also check whether your end to end LSP is upon, using MPLS ping/trace.
HTH-Cheers,
Swaroop
2227
