Community Member
1721 Boot Issue
I have a issue with 1721 router when ever it boots up all the configurations are gone and it boots up in System Configuration Mode.And after pressing no on all configurations and router>configuration memory it shows the configurations i want the router to boot up directoly
1 ACCEPTED SOLUTION
Silver
Re: 1721 Boot Issue
Check the value of the Configuration register on the router (you can see the value at the end of "sh version" output). If it is not 0x2102, the change to that value:
router#config t
router(config)#config-register 0x2102
router(config)#exit
router#copy run start
router#reload
Silver
Re: 1721 Boot Issue
router#config t
router(config)#exit
router#reload
Community Member
Re: 1721 Boot Issue
Thanks Ahmad east or west u r the west
Community Member
Re: 1721 Boot Issue
I mean the best
109
