2520 console connect help!
HI! i need help fast!!! how can i connect to a 2520 router console and with what program and settings! i have the cable, but nothing is showing up under hyper terminal!! thx!
1 REPLY
Re: 2520 console connect help!
Hyper Terminal will work. You need a baud rate of 9600, 8 data bits, 1 stop bit, no parity, and no flow control. Also, make sure you're using a rollover or rolled cable (straight through or cross over cables will not work).
103
