2600XM & Campus Manager
Hi. I'm have several Cisco router 2600XM , connected in a line by way of VWIC-MFT-E1. All is OK (CDP, SNMP, routing, connectivity), but Campus Manager (3.3) dont show links between serial interfaces (created by "channel-group" command) on topology map.
With any others routers (2600, not XM; 2800, 3800, 3600), working in similar configuration all OK.
Silver
Re: 2600XM & Campus Manager
Yes, Campus does not recognize channelised E1/T1 on Cisco 2600XM/3600 routers. Check out the following link for a similar issue :
http://wwwin-tools.cisco.com/casekwery/getServiceRequest.do?id=601037560
Thanks. But link dont work :((((
More precise for my problem:
Campus not view ANY logical interface (Loopback, BVI, Serial- and Ethernet-subinterface) on 2600XM routers. That is not view interface like "Serial 0/0:0"
Campus view only phisical interface, e.g. E1 and FastEthernet.
With 3600 router all ok.
At the same time, Detail Inventory into Device Center view all interfaces for 2600XM.
110
