2811 Router-QOS with BT RADMUX
Hi Guys,
I am connecting two WAN Sites A & B via 4Mb Metro ethernet connection. On Site A, FE0/0 is connected to Site B. FE0/1 is connected to user PC and F0/2 is connected to BT RADMUX Voice system which is communicating with another BT RADMUX at Site B. Now customer want to make sure that this 4mb BW is distributed evenly b/w PC at F0/2 and BT RADMUX at F0/3. What is the best qos strategy to use to guarentee 2MB BW for each connection? ALso please let me know if there is any special settings to be required on router for BT RADMUX VOice system as I am not able to get good quality voice at the moment.
Many Thanks
Purple
Re: 2811 Router-QOS with BT RADMUX
You initially mentioned that the PC was connected to Fe0/1 and the RADMUX to Fe0/2. But later you stated that the PC was connected to Fe0/2 and the RADMUX to Fe0/3. I've used the first set of ports in my config below - change them if they are not correct.
In order to distribute traffic evenly between the PC and RADMUX, you could use the following:
class-map RADMUX
match input-interface FastEthernet0/2
policy-map PolOut
class RADMUX
priority 2000
policy-map Shaper
class class-default
shape average 4000000
service-policy PolOut
interface FastEthernet0/0
service-policy output Shaper
You will also need to apply a similar policy to the fastethernet interface at the other end...
This policy will do the following:
- it will give priority to your RADMUX traffic and guarantee it 2Mbps of throughput
- when there is congestion, the RADMUX traffic will be limited to 2Mbps, leaving the other 2Mbps for your PC traffic.
- when there is no congestion, either of the RADMUX or PC traffic can use the excess bandwidth.
- you will find that with this setup, the latency/jitter for your voice traffic is likely to improve as well.
If you want to set a hard limit on the RADMUX traffic so that it does not exceed 2Mbps even if there is no congestion, use the following policy to replace the PolOut policy above:
policy-map PolOut
class RADMUX
police 2000000
priority 2000
Hope that helps - pls rate posts that help.
Paresh
Thanks for the response Paresh.Sorry for making confusion in FE numbering.
I will apply the config tomorrow and will post the outcome.
Cheers
Hi ,
You mentioned to apply the same service policy at other side Router B. However problem is that on other side RADMUX is not connected to device itself. Instead RADMUX is connected to switch, which is connected to Site B Router.how should the policy be applied in such case?
Purple
In that case, you need to use some mechanism that will uniquely identify the RADMUX traffic. Does all traffic from the RADMUX have a specific IP address ?
If so, let me know and I can tell you how to modify the config to suit that...
Pls do rate posts that help.
Paresh.
yeah thats right. Both Sites BT Devices have got IP addresses 10.90.1.1 and 10.80.1.1.
Purple
Then you can use the following:
class-map RADMUX
match access-group 10
policy-map PolOut
class RADMUX
priority 2000
policy-map Shaper
class class-default
access-list 10 permit 10.90.1.1 ! use this for one of the sites
access-list 10 permit 10.80.1.1 ! use this for the other site
Hope that helps - pls rate the post if it does.
Paresh
Thanks. I have implement that but user still complaining of breaking in voice. Voice works fine alone but as soon as other data traffic comes on circuit(no matter how much) voice starts getting problem.seems to me that router is not handling Voice traffic as it should.The voice traffic is REAL time and not Streaming.
Just to reconfirm that access-list should include source IP. i.e access-list implemented at site-A shoud have the IP Address of BT system at SIte A and so on..
Just to add on that I am using 2811 ROuter. PC is connected to F0/1 which is Router FE port. However voice is connected to F0/0/0 port(4 pot wic) which is actually a switch port so I have to configure a vlan ID on that and include that vlan20 into routing.
not sure if it makes any difference ..
Is there any better alternative?
Purple
I believe the idea is right for you...we may just not be matching on the right traffic. Could you get me the output of 'sh policy-map interface fast0/0' with this policy in place ?
Paresh
#sh policy-map interface fastEthernet 0/0
FastEthernet0/0
Service-policy output: Shaper
Class-map: class-default (match-any)
2281923 packets, 1193356941 bytes
5 minute offered rate 967000 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
4000000/4000000 25000 100000 100000 25 12500
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 2281925 1193357531 7 7351 no
Service-policy : PolOut
Class-map: RADMUX (match-all)
2264992 packets, 1191383732 bytes
5 minute offered rate 964000 bps, drop rate 0 bps
Match: access-group 10
Queueing
Strict Priority
Output Queue: Conversation 136
Bandwidth 2000 (kbps) Burst 50000 (Bytes)
(pkts matched/bytes matched) 2/1052
(total drops/bytes drops) 0/0
16932 packets, 1973209 bytes
5 minute offered rate 2000 bps, drop rate 0 bps
Match: any
Purple
Hmmm...that looks like the classifier is working. Also, were you experiencing any problems with the voice at the point in time that you took this capture ? It's just that there was no congestion happening at that point in time so the queueing wasn't doing much at all... Are you absolutely sure that the voice is working fine when there is no data traffic on the link.
Are you absolutely sure that there is no data traffic coming from those 2 IP addresses you mentioned ? If so, we might have to get a bit more granular...
Paresh
There is no data service running at the time of capture. May be I will capture the output again tomorrow when both data and voice services be used together.User confirmed no problem with voice when running alone.
Its BT Device sending VOICE only so I dnt expect any data packets. Also I beleive that we have set policy on Source IP addresses, means everything coming from this IP is prioritized so even if data is part of that communication , should it not be prioritized as well?
Should we look into further deep on port basis?
Purple
What I meant was.. if there is data traffic coming from those addresses, that will indeed get prioritised together with the voice traffic which you do not necessarily want.
I would like to see the above output when you have data traffic on the link as well...
Paresh
Hi mate,
Here is the current output with data running.
FastEthernet0/0
16414221 packets, 8578233312 bytes
5 minute offered rate 972000 bps, drop rate 0 bps
Match: any
Traffic Shaping
- 0 16414251 4283281334 121 91437 no
16281810 packets, 8564230000 bytes
Queueing
Strict Priority
(pkts matched/bytes matched) 49/25774
132411 packets, 14002786 bytes
5 minute offered rate 7000 bps, drop rate 0 bps
Match: any
Purple
Good morning...
So are you experiencing poor voice comms at the moment ? From what I can see, there is no congestion on the link as such...
Paresh
Purple
It appears as if the router is not the issue here. You mentioned that there was a switch at the second site. There is a possibility that the switch is the issue here. What sort of switch is it ?
Paresh
Yeah Site B is using Cisco Swith 4506. BT Voice system is connected to one of FE port on this switch. The switch connects with SIte B Router, which is connected with SIte A router on F0/0 interface.
Cheers
Purple
Is there any chance you could post the switch config for those 2 ports ?
Also, is the voice perfectly clean with no data present ?
Paresh.
Hi Paresh,
Configs below as requested.Yes user claim that voice is clear when use alone.
Many thanks for your support.
Cheers
SITE B ROUTER:
interface GigabitEthernet0/3
desc 4 mb Metro ethernet to Site A
ip address..
no ip redirects
ip pim sparse-mode
duplex full
speed auto
service-policy output shaper
#sh policy-map interface gigabitEthernet 0/3
GigabitEthernet0/3
21498828 packets, 10955737425 bytes
5 minute offered rate 1173000 bps, drop rate 0 bps
Match: any
Traffic Shaping
- 0 21432631 2317875901 184786 127267321 no
19689385 packets, 10356614450 bytes
5 minute offered rate 1036000 bps, drop rate 0 bps
Queueing
Strict Priority
(pkts matched/bytes matched) 58682/30866732
1809443 packets, 599122975 bytes
5 minute offered rate 136000 bps, drop rate 0 bps
Match: any
SITE B SWITCH:
interface GigabitEthernet3/29
description **BT-RADMUX**
switchport access vlan 25
switchport mode access
speed 100
duplex full
spanning-tree portfast
spanning-tree bpduguard enable
sh int g3/29
GigabitEthernet3/29 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0013.7fe8.f3ac (bia 0013.7fe8.f3
ac)
Description: **BT-RADMUX**
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
reliability 255/255, txload 2/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Last input 5w5d, output never, output hang never
Last clearing of "show interface" counters 00:26:38
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1040000 bits/sec, 237 packets/sec
5 minute output rate 1045000 bits/sec, 240 packets/sec
394336 packets input, 208927714 bytes, 0 no buffer
Received 25 broadcasts (0 multicast)
399665 packets output, 209390771 bytes, 0 underruns
0 lost carrier, 0 no carrier
SITE A Router :
desc 4 Mb Metro ethernet
ip address
ip pim sparse-mode
duplex full
speed auto
interface FastEthernet0/1
description **Data Lan **
ip address
ip pim sparse-mode
ip cgmp
duplex full
speed 100
interface FastEthernet0/0/0
desc **BT RADMUX*
duplex full
speed 100
interface Vlan25
ip address ...
# sh policy-map interface fastEthernet 0/0
FastEthernet0/0
18557222 packets, 9689119807 bytes
5 minute offered rate 1042000 bps, drop rate 0 bps
Match: any
Traffic Shaping
- 0 18557258 1099202372 121 91437 no
18387110 packets, 9671617800 bytes
Queueing
Strict Priority
170112 packets, 17501481 bytes
5 minute offered rate 6000 bps, drop rate 0 bps
Match: any
Purple
Could you try changing the Shaper policy so that it looks like:
policy-map Shaper
class class-default
shape average 4000000 16000
Paresh.
Its seems that everything is working fine with existing policy..ther was some problem in BT equipmetn which was causing noice problem and has been resolved..Thanks for all your help..you Deserved 5 :)
Purple
I'm happy to see that your problem has been resolved.
Paresh
548
