Webcast-Catalyst9k
2851 Voice Gateway router spitting out info??
Hi all,
I did some debugging on a voice gateway earlier and even though I turned debugging off, I am getting this output on the router:
51-1#undebug all
All possible debugging has been turned off
CAMON1GW2851-1#
*Nov 18 16:03:39.656: %ISDN-6-CONNECT: Interface Serial0/1/0:21 is now connected to 5148303255 N/A
*Nov 18 16:03:59.796: %ISDN-6-DISCONNECT: Interface Serial0/1/0:22  disconnected from 14166614460 , call lasted 154 seconds
*Nov 18 16:05:50.344: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  disconnected from 5142167051 , call lasted 247 seconds
*Nov 18 16:05:57.188: %ISDN-6-DISCONNECT: Interface Serial0/1/0:21  disconnected from 5148303255 , call lasted 137 seconds
*Nov 18 16:07:10.104: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to N/A N/A
*Nov 18 16:07:24.604: %ISDN-6-CONNECT: Interface Serial0/1/0:2 is now connected to 4182660394 N/A
*Nov 18 16:07:34.056: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 5144950842 , call lasted 591 seconds
CAMON1GW2851-1#
*Nov 18 16:07:49.356: %ISDN-6-CONNECT: Interface Serial0/1/0:22 is now connected to 12125919190 N/A
*Nov 18 16:08:30.504: %ISDN-6-DISCONNECT: Interface Serial0/1/0:20  disconnected from 5144489834 , call lasted 691 seconds
*Nov 18 16:09:07.204: %ISDN-6-DISCONNECT: Interface Serial0/1/0:2  disconnected from 4182660394 , call lasted 102 seconds
*Nov 18 16:09:07.208: %ISDN-6-DISCONNECT: Interface Serial0/1/0:22  disconnected from 12125919190 , call lasted 77 seconds
*Nov 18 16:09:22.152: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 5142861066 N/A
*Nov 18 16:11:18.852: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 5142861066 , call lasted 116 seconds
*Nov 18 16:12:54.500: %ISDN-6-CONNECT: Interface Serial0/1/0:22 is now connected to 5142783222 N/A
*Nov 18 16:13:09.248: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 4169677282 N/A
*Nov 18 16:13:48.200: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  disconnected from unknown , call lasted 398 seconds
*Nov 18 16:13:50.700: %ISDN-6-CONNECT: Interface Serial0/1/0:21 is now connected to 5149480888 N/A
*Nov 18 16:14:32.380: %ISDN-6-DISCONNECT: Interface Serial0/1/0:22  disconnected from 5142783222 , call lasted 97 seconds
*Nov 18 16:14:38.956: %ISDN-6-DISCONNECT: Interface Serial0/1/0:21  disconnected from 5149480888 , call lasted 48 seconds
CAMON1GW2851-1#
*Nov 18 16:16:15.296: %ISDN-6-CONNECT: Interface Serial0/1/0:22 is now connected to 5149257748 N/A
*Nov 18 16:16:26.236: %ISDN-6-DISCONNECT: Interface Serial0/1/0:22  disconnected from 5149257748 , call lasted 1
How do I turn this off?
Can someone advise if you know?
Thank you!
1 REPLY
Re: 2851 Voice Gateway router spitting out info??
I got this figured out, "term no mon" did the trick!
415
