2950 management
Hi.
My customer want a software of management based in Web and upgrade IOS without stop the operation. Anybody can help me?
Silver
Re: 2950 management
Hi Peterson,
have a look on the Cisco Network Assistant. It is for free and supporting the 2950 Series.
http://www.cisco.com/en/US/products/ps5931/index.html
Best regards,
Frank
Re: 2950 management
Hi Frank.
But i think that CNA not support upgrade IOS without stop the operation switch. Or support? I don't know if exists it!
Peterson
Re: 2950 management
It is not possible to upgrade the IOS on a Catalyst 2950 without restarting the switch.
You can install the new IOS image on the switch without a reboot but you will need to restart the switch for it to load the new IOS image and to start using it.
Silver
Re: 2950 management
you *must* reboot the devices after IOS Upgrade. There is no choice.
Best regards,
Frank
Re: 2950 management
Yes!
My customers wanted it and i don't knowed this solution. So, my opinion is correct!
107
